Question about Toshiba 36A40 36" TV
Toshiba 36a40 tv continually cycles thru all it's functions- all menu items, tv,video 1,video 2, video 3 and won't stop. i've tried everything i can think ofbut there is no stopping it.
  • 2 more comments
  • howie51 Oct 30, 2007
    Your solution worked perfectly.  I thought set was history.  Thank you, thank you, thank you.
  • Anonymous Apr 02, 2008
    I am having the same problem and it while it is rolling through all your buttons become dead. I tried what you suggested for Howie, but it is not working for me.
  • Anonymous Dec 10, 2008
    I've been having the same problem for a while now.
    Cycles through every menu option and then through t.v, video 1 and so on.
    eventually the remote stops working and the volume and channel buttons on the front of the tv do not work.
    I will attempt to see if it is in demo mode.
  • kator26 Jan 28, 2009
    My set is doing the same thing - continually cycling through the "menu" items. I have tried to select "Demo Stop", but it goes to next option & will not let me select the stop option. I have programmed my cable remote & the "exit" button will stop it, but only momentarily. HELP !!
    Genius:
  • 1,694 Answers
Your set is  in demo mode---your owners manual will help----
 Try holding Menu & power on (front of set) four seconds or
 maybe vol up & channel up at same time......T.
Posted on Oct 29, 2007
No radio stations
Short of it being taken back to factory reset via its menu system, which most will do in some way (Initial setup sequence) the other possible cause could be its tuner which may have a partial fault if so then it is possibly a service call out. Unless its a simple job, sadly these days it will have to go to a service centre contact Toshiba for a local repair place they will have better knowledge of your item.
Feb 15, 2015 | Toshiba 36A40 36" TV
Toshiba tv won't turn on
Check and replace damaged component/s in its main power supply regulator circuit.
Feb 24, 2013 | Toshiba 36A40 36" TV
Reset printer
Please print printer settings configuration page. The page will explain the printer menus and change values. Menus are represented by Continue, Ready/Data, Toner Low and Load/Remove Paper light sequences. Menu Items and their values are indicated by Paper Jam and Error Light sequences
Here are the instructions to do that:
1. Turn off the printer.
2. Open the front access cover
3. Press and hold the red Stop button while powering up the printer.
4. The lights should cycle, release it when the light stops cycling.
5. Close the cover once the ! light displays
6. The lights should cycle again.
7. Then press the Continue button.
8. This should print a Printer Diagnostics page.
9. On the Printer diagnostic page, Use the Utilities menu to troubleshoot printer problems
- Return the printer settings to factory default values.
- Sometimes resetting the printer to the original settings solves formatting problems.
- All menu items are reset to the factory default values except:
- All settings in the Parallel menu, Network menu, and USB menu.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are deleted.
- Resources in flash memory are unaffected.
10. Please locate the value that would say "Factory Defaults".
11. We would need to follow the exact light sequence that you see for the "Factory Defaults".
12. Press and release the Cancel button to advance through the menus and the menu items to the one we would need.
13. Press and hold the Continue button until all the lights cycle to save the function/value.
14. Restart the printer.
Jun 16, 2011 | Lexmark E260dn Laser Printer
MY REMOTE CONTROL DOES NOT WORK AFTER DARK
bdale
You may have IR interference at night because of other items you turn on at night. Try leaving everything off except your TV and receive, try your remote to make sure it functions. Then turn 1 item on at a time, try the remote to see if it works or stops working. Once it stops working, the last item you turned on is causing the interference. It is then a matter of relocating that item so it won't continue to interfere with the remote functions. I hope this helps.
Ray Calo
DISH Network
Nov 22, 2010 | DISH Network IR Remote Control
Toshiba 32" Model# 32A33 TV About 5 years old
change tact switches
you have windex syndrom
using too much windex cleaning tube
Aug 26, 2009 | Toshiba 32A33 32" TV
TV cycles thru tv mode, av1, av2, component 1, component 2 mode, s-video, DVI, ect...continuously every 10 seconds or so. Will not stay on one signal.
Ur board is short,tries to unplug everythings clean it wait couple hours plug back in.If this still hapen, it ur board it bad need it to be replace.
Aug 25, 2009 | Samsung DynaFlat TX-P3064W 30" TV
Toshiba CF27H50 cannot switch from TV to Cable
Have you tried pressing the cable or TV buttons on the remote?
I hope this solution is helpful.
Feb 13, 2009 | Toshiba CF27H50 TV
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
Jun 10, 2008 | Toshiba 36A43 36" TV
Toshiba 36A40 36" TV Logo
134 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
