PRINTER ADVANCES PAPER HALF WAY AND STOPS. IT DOES THIS WITHOUT SENDING ANYTHING TO PRINT. IT CLEARS IF THE "X" BUTTON IS PUSHED, BUT WILL RESET AND START OVER. IT ALSO MAKES A LOT OF NOISE WHEN RESETTING
Step Press Displayed Result Notes
1. Install the ribbon, load paper, and power on the printer.
2. NOT READY Printer must be in NOT
READY mode to access
the tests.
3. OPERATOR MENU
UNLOCKED
Unlocking ENTER key
allows you to test the
printer.
4. OPERATOR MENU
PRINTER CONTROL
First of series of
configuration menus.
5. OPERATOR MENU
OPERATOR PRINT TESTS
Advances to the Operator
Printer Tests menu.
6. OPERATOR PRINT TESTS
PRINTER DEMONSTRATION*
Advances to first option in
Operator Printer Tests
menu.
7. OPERATOR PRINT TESTS
[TEST NAME]
Cycles through list of
tests. Stop when your test
displays.
8. OPERATOR PRINT TESTS
[TEST NAME]
The test you selected
starts printing.
9. NOT READY The printer test stops
printing.
Stop
Scroll + Scroll¯
Menu
Scroll UNTIL
Enter
Scroll UNTIL
Enter
Stop
Let me know if you need any other help with this. I carry all parts and refurbished units and offer free techincal support as long as the parts ordered thru us.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240 [email protected]
it may have more to do with the type of paper and your canon printer. did you check to see that the paper is compatible with the printer specifications?
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
