There is no sound and the screen is unwatchable with the picture scrolling to a point where you can't see anything. Occasionally the picture will return to normal for a short time. TV is a Insignia NS-32LCD.
  • 10,594 Answers
Unplug TV from AC outlet for couple of minutes, replug back in and power it up. Let me know if problem still exist.
Posted on Jun 11, 2009
SOURCE:
Where is the reset button a gravity3
Instructions
    • 1
      Unlock your cell phone (if necessary). From the main screen select "Menu"; this option should be located on the lower left-hand side of the screen. Scroll to and select "Phone Book." The screen will show different phone book menu options. Select "Management" by either scrolling down to it or punching the #6 button from your keypad. Finally, select "Copy all to" and select SIM card. This saves all of your phone numbers to your SIM card, ensuring that they will not be lost when the factory settings are restored to your cell phone.
    • 2
      Move any pictures, videos, sounds, ring tones and other data that you would like to save to your memory card. For this example we will transfer pictures, but the steps for other items will be the same, with the exception of selecting "camera."
      Starting from the home screen, select "Menu" and then "Fun & Apps." Using either the keypad or scrolling function, select "Camera" or #4. The camera menu offers five options; choose #3 or "Photos." Next you will see thumbnails of all of the pictures saved on your cell phone. You can now choose to either send your pictures to your online album or move them to your memory card. If you choose to move them to your memory card, continue with the next steps.
      After selecting "Move to memory card", you will have the option to move either the selected picture or multiple pictures. The simplest option is to move multiple pictures at one time by choosing "All" and then "Move."
    • 3
      Complete the factory reset by once again starting at the main screen and choosing "Menu." Scroll to "Settings" (screw driver and wrench icon) and then #4 or "Phone Settings." Choose "Security" (#6) and then scroll to "Reset" (#8). You may be prompted to enter a code at this point, which should be 000000 (six zeros.)
      Hope this helps you :)
Jan 25, 2012 | Samsung Cell Phones
Dish vip 622 and vip 722k frequent picture freeze and restart
Sounds like a signal strength issue. You may have either a low signal or something like a tree limb is blowing into the signal path dropping the signal strength to a point low enough to causes issues.
Apr 13, 2010 | Televison & Video
My wide screen projection tv is 2002 model and first thing in the morning when it is turned on it shows double menus and pictures until it warms up. what can you help me with?
It sounds like your bulb is starting to go bad. It's actually very surprising you haven't had this problem earlier, as some bulbs will only last a few years.
You can take it to a repair shop and have your bulb replaced, but it sounds like you have a little bit of time before the bulb makes your TV unwatchable.
Jan 30, 2010 | Sony KP-51HW40 51" Rear Projection...
Problem with Lag between picture and sound
There should be a setting in the Home theater's menu (probably under Audio or Audio Setup) to increase or decrease the delay. Set this to the least possible delay, or if possible, no delay at all. This, from what I read is a very good unit so it should have this setting in the 'Menu', if you can't find it, the manufacturer should be able to help. Good Luck!
Dec 11, 2008 | Samsung HT-Q100 System
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Screen Brightness
Your ballast may not be up to 100% of its rated capabilities, thats often the cause when the brightness level gets to unwatchable levels. You may need to troubleshoot the ballast voltages a defective ballast can usually cause a lamp to loose about 60 % of its brightness levels. The other possibility could be the DLP mirrors need polishing but that is something better left to a repair shop as the DLP mirrors are sensitive
May 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Bleeding picture - unwatchable
Sounds like to me the set has some cold solder joints or fractures that are changing with temperture and can be fixed possibly. Are you located locally to me? i may be able to assist with the repair of your unit. Let me know and good luck. Jay
Jan 31, 2008 | Relisys RTL1720 17 in. LCD Television
Picture scrolls on all inputs except Componenet
It certainly sounds like a defective capacitor. Was the storage area hot? Electrolytics can dry out and change value over time or flat out short out. They don't cost that much and it sounds like you know what you're doing around TVs. I would start in the vertical circuit and replace all electrolytics. Also look closely at all connections with magnification and solder anything which looks suspicious. If you have a scope and know how to use it a check of various waveforms should identify the culprit. Good luck and remember safety.
Jul 02, 2006 | Apex Digital PF2720 27" TV
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Ekse
