Home | Princeton Digital | VL1918 (Black) Monitor | Lines on upper left cor...
Princeton Digital VL1918  Monitor
Problem for Princeton Digital VL1918 (Black) Monitor
Lines on upper left corner, inside of screen
By joeadler on Jun 11, 2009
Upper left corner, 1.5" high x 3" across, black lines cover up whatever is behind them. Configuration ofd lines looks like the following:
______ _______
_________________________________
____________ _____
about twelke such lines, approximately 2 mm apart.
Looks like lines are on the inside of the clear plastic cover. Cannot reach inside the protective cover to wipe them.
Solution #1
posted on Jul 24, 2009
Not Rated)
Philipreid
Rank: Wiz
Rating: 78%, 10 votes
is the correct driver installed? or does it need reinstalled
Was this helpful?
Yes
No
Solution #2
posted on Jun 11, 2009
Not Rated)
binesheb
Rank: Wiz
Rating: 76%, 52 votes
its problem with the display cable (not the one you connect to your pc)
open the lcd display and look for a cable that is attached to the front glass display. check whether it is dameged.. it cannot be replaced
you need to replace the whole display that would be better. and cost effective
Was this helpful?
Yes
No
Popular Solutions for Princeton Digital VL1918
Questions and Unsolved Problems for Princeton Digital VL1918
Do you recommend Princeton Digital VL1918 (Black) Monitor?
Answer
Answer
I have a Princeton VL1918 Monitor with built in speakers. the volume is to low. how do I increase... (More)
Answer
It is a bit blurry and I want to know if there is a way to adjust the focus, or sharpness. None of... (More)
Answer
Princeton VL1918. Speakers stopped working. Check all connections. Other functionality is OK.
Answer
The Mac Mini that it's attached to is generating a proper video image, since I can mouse and click... (More)
Answer
not disappear the volume bar on the monitor all the time
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Princeton Digital VL1918 ...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 480
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
