Question about Acer AL1916W 19" LCD Monitor
Annoying Nuisance on the monitor
The minute the computer starts up an annoying gray box outlined in white starts moving around on the screen kinda like how a dvd player when it shows its screensaver. It goes in all directions. The text in the box says, "input not supported". How do I get rid of it??? The monitor I have is an AL1916 so it's not the widescreen version. Can you give me a helpful solution? Thanks
  • judiwho2 Aug 31, 2008
    I have had an Acer desktop for about a month now. It has been working fine up until today. I went to turn on my computer and all I can get is "input not supported" in a little gray box that moves around the screen. It won't even let me boot up in "safe mode". I have tried to push the f8 button at various times with no luck. I have an P191W LCD Monitor. Is there anything you can tell me?
  • israeltorres Sep 02, 2008
    input not supported
  • 146 Answers
Boot in safe mode,, set lowest resolution, if still not work.. go to device manager and check if standard monitor is there in the list, and if nt there add it manually....
Posted on Jan 26, 2008
Run your system in 'Safe Mode'. Go to Display settings and set lowest possible resolution. Then restart computer and run windows again in normal mode. Should have normal screen. If this will not work - then under safe mode uninstall graphic card. Then run windows with standard ones and in LOWEST possible resolution install drivers again. I have had it many times and it made swear first time.
Posted on Nov 05, 2007
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Brightness box in the middle of the screen - will not go away
open case remove white header plug from back of switches and voila ..... none of the buttons will work or the power led but display is fine with no annoying menu
Jun 16, 2011 | Samsung SyncMaster 720N Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
I have a problem with my hp 1702 please help!!!!
this means that your screen settings are not compatible with the game. like 16 bit color to 32 bit color. set the screen settings so that you can play. Display properties would let u adjust these colors.
Aug 11, 2008 | HP L1702 17" LCD Monitor
Brightness box
I suggest you to track faulty component at logic board.
Apr 19, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Annoying discolouration across monitor
Does your monitor uses external Power Supply Unit ?
May be the video board need services.
Feb 13, 2008 | Acer AL1916W 19" LCD Monitor
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Oct 26, 2007 | Dell E173FP (Black) (Dark Gray) 17" LCD...
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1916W 19" LCD Monitor Logo
140 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
