Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Does not power up
Red LED flashes 6 times and turns off.
  • jibad Nov 25, 2007
    No light comes on.
  • mattinb Mar 07, 2008
    mine does not power up but i don't even get the blinking on the red light, it stays on, and then it doesn't shut off by using the remote. Also i should mention that this has happened since i moved. i have tried turning it on and off every 30 seconds and unpluging it and trying it again to no avail.
    Genius:
  • 1,694 Answers
Research at www.HitachiServiceUsa.com ............T.
Posted on Nov 09, 2007
It works intermittenly
3) The LED turns on or flashes red during initial boot up :
When the temperature inside the car is too high or too low, the red LED flashes. In this case,
follow the steps below.
Turn the product power off and ventilate the car to return to normal ambient temperature.
Turn the power on after a little while and observe the LED color.
If the red LED still flashes under normal temperature, contact customer service.
Ref: Plenio VXA3000 Users Manual Pg 5/6 1-4 Troubleshooting
DVSSynchrome_VXA-3000_UserManual.pdf
Download Files At MS Skydrive Email jeffreydrescher@Bellsouth.net For
Login and Password
Dec 23, 2013 | Digital Video Systems Plenio VXA-3000 GPS...
My tv (32PF321D/37) won't turn on and the power light is flashing red six times, pausing, then doing it again. Any ideas?
Check bulging capacitors in power supply that causing 6 red LED flashes. Replace them and fix the problem. philips-32pfl5322d-37-04.jpg?w=770
Feb 01, 2011 | Philips 32PF7321D 32 in. LCD Television
Power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red led flashing 6 times
Something is wrong with the power supply of the Hi Voltage section
Oct 08, 2009 | Sony KDF-E55A20 55 in. LCD Television
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
KDS-60A3000 new bulb gets 6 flashes of red led
Please put back lamp (bulb) cover properly and check as lamp cover is open/ not fixed or improper fix is also cause of LED flashing.
Jan 08, 2009 | Sony KDS-60A3000 60" HDTV
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Television won't turn on
If its a DLP tv chances are the bulb went out, double check with the manufacturer before getting as they are not cheap, around the $250 range.
Oct 26, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
