r
rodenise joseph Posted on Feb 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Linear relationship Explain how you can use a linear function to solve this problem. Then, solve the problem.
k24674
Level 3:
  • Office Equip... Master 8,093 Answers
  • Posted on Feb 28, 2014
k24674
Level 3:
Answers
8093
Questions
0
Helped
4674971
Points
21596
If you keep not spelling out the TEXT of the problem, there is zero chance that you will get an answer, regardless of the number of posts you write. No one is a mind reader.
How To Do Linear Equations
Which of the following equations? What following equations?
Question Investigate the relationship between the
This is not the kind of material for this site, we are a self help repair and use site for manufactured products.
Non linear graphs
All graphs, except the linear function y=ax+b, are non-linear. To graph a function, just enter the GRAPH utility, type in the functions Y1=, Y2=, ... and press the Draw tab.
If you have a specific question, ask it.
Linear graphing on the TI-nspire
Turn Calculator ON.
In scratchpad, add a Graph.
After you press enter to graph the function you will not see anything because the y-intercept is at ordinate 254.47. To see anything you need to zoom out.
You will be prompted for the Center of new graph. Move cursor along the y-axis, upward. After a while you will see the graph.
You can also, and it is quicker, to set the graph window
Set the values as on the screen capture
Here is what you see
Enjoy.
How to do equations the papers that come with it doesn't explain it very well. Is there someplace where I can get a better explaination?
You can solve equations two ways: The EQN computational mode or the SOLVE application.
IN the EQN mode you can solve linear equations in one, two and three unknowns; the quadratic equation; and the cubic equation.
Enter the EQN mode by following the instructions on the following screen capture. Press 5:EQN
You have three types of equations.
Once you select the type of equations, a template is displayed where you enter the relevant coefficients.
Under each label (a, b, etc. ) enter a coefficient and press ENTER to move to the next. With a cubic equation, or a linear equation in 3 unknowns, you have to use the Right arrow to display the cells where you enter the value of d.
After you input all necessary coefficients press the = sign to get the solution.
To use the SOLVE feature, see the screen capture that follows. It comes from the Casio manual.
Good luck
2helpful
How can I solve linear and non-linear equations
Set Computational mode to EQN by pressing [MODE][5:EQN]
Select the type of equations you want to solve
Select the relevant otion and get ready to type in the coefficients (the a's, the b's, the c's etc`.)
For more general non-linear equations, use the SOLVE feature.
2helpful
Give an example of a linear equation, solve it, and then check your work. Explain step-by-step what procedures you used and upon arriving at a solution, carefully check to see that your solution is correct...
4x+7=11 Solve for "x".
subtract 7 from each side of the equation
4x +7(-7)=11(-7) = 4x=4
divide both sides of the equation by 4
4x/4=4/4
therefore
x=1
Correct?
k24674
ADMIN Andrew
ADMIN Andrew
