Question about Cnet CNSH-1600
VLAN - and TRUNK
What's the purpose of TRUNK and VLAN at the back of the CNET CNSH-1600 Power Switch. I had 2 LAN Cards on my PC, the other one is connected to the Internet and the other is connected to the Switch, but i can't connect from the other computer and browse files.
    Problem Solver:
  • 10 Answers
The trunk port of the switch is meant for cascading the switch i.e. you can connect another switch to that port for adding more computers.
For connecting to a multihomed PC (with 2 lan cards) Please type in static ip address to the lan card that is connecting to the switch and alos add static ip adds to all the other computers taht are to be connected for sharing. Then share the internet connection through the other lan card.
Please write to fonix@sify.com for more details
Posted on Oct 29, 2007
SOURCE:
How to configure cnet cgs-800
Hi, according to its manual, this is only an L2 switch, so no configuration is needed, if you want to use VLAN in example, you have to install an L3 switch.
Apr 30, 2016 | Cnet CGS-1600 16-Port Gigabit Switch - 16...
I have linksys srw224g4 layer 2 switch how can i create trunk port in this switch
Log into the web management of the switch.
Go to settings --> Vlan Tabb
Under the VLAN click on the VLAN and you can see the ports .
Click on the trunk box under the switch port which you want to make as trunk.
Jan 10, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
Sir I have 4200 series 26 ports Switch i want to Configure intra VLAN But I am Getting a problem to Configure that switch . After Cnfigure VLAN on Consol prompt. I am not accessing to my Server & WAN...
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
Nov 01, 2010 | 3Com 4500 24-Port Ethernet Switch
How to use the small switches at the back of CNet CNHS-1600 Power switch
Hi
If you are running the Cnet CNHS-1600 power switch in default mode ( No Vlans created) then you do not need to configure anything. Connect any Cat5 or CAT6 LAN cable from any free port to the new small switch. The Cnet CNHS-1600 power switch is Auto MDI/Auto MDI-X enabled so no need to worry about the cross cable. Simply plugging in a cable between Cnet CNHS-1600 power switch and the new switch will extend your LAN.
Oct 29, 2010 | Cnet CNSH-1600
I need a default username and password for a cnsh 800/ 8 port router
This device does not have a username and a password, nor would you ever need to log into it. Are you trying to log into your router?
Oct 20, 2010 | Cnet Technology CNSH 800 Networking Switch
IP Addressing by dhcp for vlans
tell each vlan about DHCP server using
ip helper <DHCP servers ip adddress>.
in config mode.
Mar 03, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
Can we able to trunk one vlan to another vlan
interface GigabitEthernet0/1
switchport access vlan X
interface GigabitEthernet0/2
switchport access vlan Y
interface GigabitEthernet0/3
description trunk port
switchport mode trunk
switchport trunk allowed vlan X,Y
Aug 19, 2008 | Trendware 8PORT SMART POE SWITCH SNMP VLAN...
Connection Problem
maybe its not in the hub/router, or in your lancard has the problem. try to change the networking cable you are using it sometimes the cable has a teared wire inside, or probably the lancard or your hub does not work for the type of networking cable, there are 2 types of connection for UTP cable first is the Straight through cable and the second is the Cross Over connection. Try to mix and match the cable that you have and try to use another one instead..
Nov 19, 2007 | Cnet CNSH-1600
Cnet CNSH-1600 Logo
776 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Jim LeVerso - IT...
Jim LeVerso - IT...
Pamela Bates
Pamela Bates
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
