Question about SanDisk Sansa m230 MP3 Player
Why wont my Sansa get songs???
Everything on my Sansa e200 works except one thing. everythings fine! i plug it in with the USB cord (its set on MSC mode) then i add all the songs i want. then i do the safely remove thing and teake it out. but when i check the Sansa, none of the songs i added are there. i tried adding them 2-3 times, but they still didnt appear on the Sansa. please help if you can. thanx!
You may have to install Musicmatch and add songs through the portable device menu. It worked for me. Good luck.
Posted on Nov 10, 2007
NO AVAILABLE PLAYER DETECTED!
Try going into settings, usb mode change that it should be either mtp or msc.
May 09, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e260 volume will not work?
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
Mar 10, 2009 | SanDisk Sansa e200 MP3 Player
Cant switch to MSC on sansa e260
Try this instead:
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 21, 2008 | SanDisk Sansa e260 MP3 Player
Sansa M230 not seen in Explorer or Windows Media Player
We had the same problem with Windows XP. We found some help on the Sandisk web site. On the device go to the Settings menu, then USB. We changed from AutoDetect to MSC mode and everything is working again. Our computer saw all of the songs on our computer fine. Some of the old songs on the Sansa didn't show up on the detect list in Windows Media Player, but they were still on the device.
Mar 23, 2008 | SanDisk Sansa m230 MP3 Player
Uploading songs on it
you could try putting it into recovery mode if it's like the sansa e200 series. to do this plug it into your computer and click the hold button so the orange is showing. next, hold down the record button while pushing and holding the power button at the same time. after a few seconds it should go into recovery mode and factory settings will restore. this works for sansa e200's and i hope yours is almost the same as them. try the sansa forums though they could help alot.
best of luck
Feb 14, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e200 for christmas wont connect
Make sure the USB portion of the menu is set to MSC. This should enable your computer to recognize the player.
Dec 25, 2007 | SanDisk Sansa e200 MP3 Player
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00...
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from SanDisk.com on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
My computer won't detect my music from my sansa e200 on my computer
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 21, 2007 | SanDisk Sansa e260 MP3 Player
Can't delete songs from the e200
I had this same problem with my Sansa e280, I did some research and found that MTP mode is used when syncing with Windows Media Player.  So if you plugged in your player under MTP and simply tried to drag and drop using Windows Explorer the player won't recognize.  I have heard that you should be able to view them on the Sync tab in WMP but I personally have not tried.
The way I got rid of the songs was by going into my Sansa Settings and changing the USB mode to MSC, opening the Player by going to My Computer, then (if using Windows XP) click on Tools > Folder Options.  Click on the View tab and Select "Show Hidden Files and Folders".  Click "OK" Then Right click on the MUSIC Folder and Select "Properties"  Uncheck "Read Only" and "Hidden".  Unplug your Player and it will restart.  Viola, no more ghosted songs.
Apr 30, 2007 | SanDisk Sansa e200 MP3 Player
Sansa Scandisk e205 refresh Database failed help plz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
okay, heres wut u can try. try to switch the USB mode from MTP to MSC (in settings, go to USB Mode and switch from MTP to MSC.) And then in the MSC mode connect it to the PC. I dunno bout ur sansa, but my did a Database Reboot, and the computor could see the player. Then u can switch it back to the MTP mode (czu its much mroe comfortable). Although i think the 0.5 gigs are lost forever (i lost 1.5 gigs,)atleast now u can dwonlaod songs on ur player.
Sep 28, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
