Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Kenmore dishwasher 15835
Today I noticed a dash symbot (-) lit up on the display panel and the dishwasher will not work.  The - symbol lights up whenever you press any buttons and goes out after a minute or so.  We checked all connections to no avail.  The only function that we can get to work is the 'control lock' by pressing the 'no heat dry' pad for 4 seconds.  Nothing else will work.  Thanks for all and any input.
  • mikelup Nov 03, 2007
    1999 Kenmore dishwasher model 15831793, serial#FJ1914498, STOCK# 15831 An old, but effective workhorse, accidentally bumped start button, began fill cycle, opened door to delay until evening / full load, upon restart - LED display showing horizontal dash ( - ), checked control lock - functional - off, tested keypad function - no keys are stuck, tried diagnostics; wtr heat, no heat dry, wtr heat, no heat dry - no response, just the horizontal dash , disconnected power, plugged back in - the dash still shows... thank you in advance for your help
I have the same dishwasher, and now am experiencing the same problem as listed above.
Is there a fix for this???
Posted on Apr 27, 2008
How do I cancel the control lock
It would help if you gave the brand and model number of your dishwasher, but the answer is basically the same. Look carefully at your dishwasher control panel. You probably have a little lock symbol that is lit up (or a light inside the symbol is lit). And usually this lock symbol is located near (usually above) a button that is usually used for another purpose. Most often this is the Heated-Dry key or button. Press and hold this key for 3 to 5 seconds until the lock symbol light goes out. And it's just that easy! But if you press the key, and nothing happens, then you may have a bad control console that will have to be replaced.
Feb 25, 2015 | Dishwashers
Kenmore ultra wash machine won't run even with indicator lights on. Symbol on machine says Lock on
You have the control-lock function turned on. There should be a key located near (above or below) the lighted lock symbol. Usually, it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock your dishwasher and you can now use it normally.
Jul 15, 2014 | Kenmore Dishwashers
Kenmore ultra wash dishwasher 15835 it runs fine, but when is sets after its finished it get water in it and you have to press cancel to drain it again. Any idea?
Water inlet valve needs replacing. (about $50 for the part)
The valve is leaking and allowing water to enter the dishwasher even when it's off. You can turn off the supply line shut off between uses until you get the part.
Jun 14, 2010 | Kenmore Dishwashers
Frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Mar 04, 2009 | Electrolux Frigidaire Professional Series...
Water not draining from the bottom of the dishwasher
vacuum it out with wet/dry vac and see if filter is dirty big peices of food will accumulate and stop it up if not check under sink where drain hose connects to main drain
Feb 19, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ABS symbol lights up on dash?
yes you need to have the abs system checked out...i had a suburban that did that and ended up losing my yes be concerned.
Jan 13, 2009 | 2004 Chevrolet Malibu
Control Lock light remains on
Vince, press and hold the keypad next to the lock symbol. (heated dry?) see if the lock light goes out. back
Mar 19, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
333 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
