I had gone out of town for a few days and it worked perfectly until then... the bulb was about six weeks old at the time and I have roommates so the projector wasn't exactly sitting alone for three days. The plastic where the lamp is supposed to hook in/connect is completely melted, so I would need a new part altogether (if it's cheaper than buying another). Is it possible that there is further damage that I can't see?
The standard housing is high temperature resistance. it will not be melted .
your lamp housing was melted, means that the lamp and the housing is a inferior one, the quality is not good. It will damage your projector .
Pls purchase a new one ,a good quality lamp +housing
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
http://facebook.com/lampdeng
http://www.lampdeng.com
SOURCE: NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
SOURCE: How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
SOURCE: I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
SOURCE: I have a NEC VT700
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
SOURCE: When power button is turned on it has a orange
The bulb is not lighting.
--- Please dont forget to vote this answer was helpful Many thanks ------
Make sure the covers are going on correctly if I remember this one has an inner cover as well.
There is a little micro switch that needs to be operated by cover going on correctly.
also check the plugs / connectors are ok.
