Question about Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD 52527
I have a status problem.  There is a blinking red light on my status button.  Sometimes the TV turns on, but will turn off after 5 minutes and not be able to turn on for another 5 minutes.  What can I do to fix it???
  • nichoji Nov 06, 2007
    I've got the same problem. The TV would reset after a while when unplugged. It has now got to the point where it won't turn on at all. Once the TV turns itself off, push and menu & device buttons. You'll get a green blinking light. It'll blink a number of times, pause, then blink again. My code reads as 56, shutter not connected. I don't know where to go from here.
  • Anonymous Mar 07, 2008
    same problem...dealing with no-customer service now...
I finally broke down and took it to the shop. They said they think I had some loose connections internal to the engine. They reset all the the connections and resoldered the joints. Seems to be woking okay so far. The fix cost me $310.
Posted on Dec 02, 2007
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
5738 status light blinks red 5 times then orange 7 times
if it is a 7 then u must replace.
SOURCE: i am a mechanic
Jan 21, 2012 | Mitsubishi WD-65738 DLP TV
What does it mean when the status light is blinking red on my mitsubishi wd-62526
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
I have a mitsubishi WD-52527 TV with error code 45
You have to pull the light engine to get to the pbs fan it is the one located closest to the lense on the light engine. you should be able to see if the fan is turning without removing the engine.
Sep 06, 2009 | Televison & Video
Lamp light is red
pull lamp from unit and investigate it for integrity
Jul 07, 2009 | Mitsubishi WD52527 52" Projection HDTV
The blinking status & Time LED lights
DM board n/l/a ....
the only and best way to fix this TV ! ! !
you need to replaced the chassis !!!!!!!!!!!!!!!!!
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD52527 52" Projection HDTV Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
