Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper not going into the feeder wheels
Hi there i need some help, I need to find out why my paper will not go into the feeder area of the printer. I have tried different ways and it just won't feed even though the rollers roll. Thanks call if you want to and I will try to work with you on it. I tried what was suggested in the solutions before hand and it still won't work.   thanks Wanda
  • 1 more comment
  • gameboy1627 Nov 19, 2007
    put paper in feeder it takes it then stops paper is mess up on one side
  • X infident Nov 26, 2007
    My printer won't accept the paper into the back it says E 23 so plese help me!
  • Anonymous Dec 05, 2007
    same as wicked wanda's paper wont go through
Got same problem.
I've tried to turn the printer upside down and to shake it.
I've tried to reset the printer.
The only solution was to remove the case, and lucky to pick up my little children toys parts from the printer :)
Unforunately the film cable is very tight and you and therefore is not a risc free operation. At least 16 screws. But a philips screw driver will make -it.
Posted on Dec 30, 2007
Hi my name David and I to have the 2400, my paper wont feed throu and when it does it goes throu none stop,with out printing I need help please.
I had the same problem with my R2400, it was the feeder mechanism and was fairly easy to sort (for me anyway). If you look in the paper feeder area there is a grey roundish wheel in the bottom right hand corner (looking from above and the front). It often gets dust and fluff etc in and around it and therefore fails to feed the paper through correctly. Try cleaning it with a rough-ish cloth (like a dry flannel etc) - this worked for me.
Alternatively what can also work (as I discovered myself prior to solving the problem) was having a stack of paper in the machine. I.e having multiple sheets in the paper feeder also seemed to solve the problem.
I still get the issue occasionally but it is far less prevelant.
HTH :)
Jan 04, 2013 | Epson Stylus Photo R2400 InkJet Printer
When I put the paper in, and push the refill button, the paper goes down in the printer crookid, I need help does anyone know what I could possibly do?
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Oct 07, 2011 | Lexmark X2500 All-In-One Printer
Paper is not going in straight
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
My printer X3350 has trouble grabbing the paper from the paper tray. What can is the problem. I tried cleaning the grabber wheel. But it still won't grab the paper.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 21, 2011 | Lexmark X3350 All-In-One InkJet Printer
PAPER starts to go into printer then goes crocked and stops
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
May 11, 2011 | Lexmark C533DN InkJet Printer
When printing the paper is not drawn down straight - pulls to one side - and then becomes jammed. This has happened over and over. Is there a wheel or something of track - can I fix this myself. Thanks...
There could be something that's blocking the paper feed system. Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area.
You may also refer to this article in the Lexmark website: How to Remove and/or Avoid a Paper Jam in your Lexmark X5300 & X5400 & X5600 Series All-In-One
May 10, 2011 | Lexmark X5495 Printer
Printer does not pick up paper
Good day keefer, maybe you have a technical problem with your printer. It seems that the feeder parts inside your printer needs for repair. You can go to your nearest technician in your area to solve it for you.
Hope this help.
Dec 18, 2009 | Samsung CLP 300 Laser Printer
ADF Jam
It sounds like the grabbing wheels in the document feeder are losing their grip. You can take alcohol to rub down and clean the rubber tires in the document feeder. There is a possibility that a very small piece of paper is jammed in the feeder as well, which can cause the paper to jam and make a weird noise. Please let me know if this resolves your issue. Thank you.
Mar 27, 2009 | Dell Photo 964 All-In-One InkJet Printer
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Hi there i need some help, I need to find out why my paper will not go into the feeder area of the printer. I have tried different ways and it just won't feed even though the rollers roll. Thanks call if...
This printer comes with major paper feeding problems, even on the FAQ for this printer on HP's website paper feed problem is the number 1 FAQ. It either misfeeds or won't feed paper. An average example is if you try to print a 6 page report, it will missfeed about 10 sheets to print 6, and you will spend a lot of time pushing the paper feed button.
Following the guidlines in HP's faq about this does nothing to improve the situation. HP basically denies any problem with the printer and wants the consumer to pay to ship and have the printer fixed, even if it is new. They will give you phone calls and emails with a lot of PR babble, but do nothing. Stay away from this piece of junk, HP is aware there are major paper feed problems, does nothing about them, and doesn't take it off the market.
Oct 28, 2007 | G7 Productivity Systems VersaJette M300...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
55 people viewed this question
old marine
old marine
