Question about Toshiba 43H70 43" Rear Projection Television
Globe Trying to find a price for the globe and where to get them. There is sound but no picture. Can the cause just be the globe
  • Toshiba Master
  • 8,617 Answers
I think you refering to the CRTs, but thats not your problem you have a deflection problem. Maybe one of the regulators or vertical or horizontal circuits with a little trouble shooting you should be able to fix this issue. Check the transistors.
Posted on Feb 01, 2008
Brake light and license plate lights won't work
All lights rely on a good connection between the globe base and the metal body of the car.
This is the cause of your problem.
You'll probably find rust in the globe holder stopping the globe from making a good connection.
You may have to replace the globe holders, but it will be worth trying to clean the rust back to bright steel.
May 02, 2014 | Cars & Trucks
HOW DO YOU SET THIS TIMER?
1) Globe 82428201 Indoor Timer appears on following page:
http://www.amazon.com/Globe-82428201-Indoor-Timer-2-Pack/sim/B000GC41RU/2
2) Open following link that goes to instructions are identical to 82428201.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59419
3) If this is not your timer, add a comment with clear description of timer and identifying numbers.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Globe Electric Globe Indoor/Outdoor Lights...
How to change the bulbs I turn and turn the globe and lower assembly but the glass doesn't release! The shaft rises up slightly but then clicks back down Any suggestions?
Hampton Bay assembly information is tough to come by on the internet - except for sales info. As an electrician, I have hung more fans than I can remember, and have never found any that were not secured by either (1) three or more thumb screws, (2) a threaded portion of the glass globe or (3) a "bayonnette" (quick twist) type mount that required little more than an inch or so of twist to remove.
The globe should be removed by either loosening / removing three or more thumb screws that are designed to engage the recess between the globe itself and a lip around the opening; unscrewing the glass globe light a light bulb ; OR by twisting the globe about an inch or so in one direction or the other (like many automotive-type lamps). I suspect the type you have is the latter. From your account of what is happening, it suggests to me that the entire fan / light fixture is twisting on the fan support on the electrical ceiling box when you are trying to twist the globe. The globe and rest of the fixture are moving as one instead of independantly of each other.
If yours is the type that must be twisted from the base, you'll need to prevent the rest of the fixture from twisting at the same time while attempting to remove the globe. This will probably require a second person to help - given that it seems to have become wedged in place, and trying to grip it and balance the globe might be to much to do by yourself. If yours is held in place by thumb screws, no amount of twisting will allow it to be removed.
There should be no "secret" way of accessing the light bulbs, something has happened that is preventing the easy removal of the globe - whether it is corrosion, dirt or some other debris. Make sure you clean it up completely before reassembly.
I hope this helps! Good luck!
Nov 04, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
We have the lighted movable Fisher Price Globe. Problem is... it won't move... seems to be stuck. Can you tell us how to release and what to release so it is free flowing? "thanks"
I just bought one at a flea market today, and had the same issue. After a couple of searches, I came up with the solution. An Etsy seller had this to say: "You might be afraid that the globe is "stuck" and won't turn, but you just have to be firm to turn the globe. You'll hear loud clicking when you turn it; this is because the globe is made to stop at certain points so that the viewer can easily meet up with the white dots." I tried turning mine firmly, and it did finally make a loud click and turn. It does not spin freely like a normal globe, though. I also found a PDF of the original instructions: http://service.mattel.com/instruction_sheets/76609.pdf
Sep 06, 2010 | Fisher Price Toys
I cannot remove light cover on ceiling fan to replace globe
There are usually small screws around the outside of the globe that screw into a recess on the globe with a rubber ring around it to keep the screws from hitting the glass.
Dec 31, 2009 | Sewing Machines
Leap Frog Smart Globe Pen broke - which replacement pen do I order?
Hi, I just ordered 2 pens - the price was $5 per pen including S+H. I was told that the globe that we have ( smart globe, purchased in 2003 or so ) is a discontinued model so I just ordered an extra one just in case. The pens should arrive within 10-15 business days according to the costumer rep. Good luck!
Oct 20, 2009 | Toys
PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Feb 07, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Toshiba 43H70 43" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
