Question about Compaq Armada M700 Notebook
Unplugged my armada m700
Hi i unplgged my armada m700 due to it was blocked and now when it restarts it does nothing but show the compaq logo or switches to a message saying :fixed disk parameter or bios error
system halted
pls help me resolve this because this the only laptop i have to continue my studios.
  • George Francis
    George Francis Jan 30, 2009
    I have same problem, M700 with power on password. where is cmos/bios battery as I don't have a manual. How do I reset password. Laptop was from auction deceased estate.
  • 1,006 Answers
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Posted on Oct 29, 2007
How will I know if my laptop Compaq Armada m700 is fully charged already?
Hi
You do not say which operating system you are using.
Right click on the toolbar at the bottom of the screen > properties > notification area > tick the Power under System Icons - Select Which Items to always show > Apply > OK > float the mouse on the battery icon to see % of charge and charge time remaining.
I hope this helps.
Aug 24, 2011 | Compaq Armada M700 Notebook
Just installed intillinet wireless g pc card, it wont work
Does the card show up in device manager? with no exclamation or questionmark next to it?
Jun 21, 2009 | Compaq Armada M700 Notebook
Installing wifi in Compaq Armada m700??
yes, aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series it's alot better
Jan 25, 2009 | Compaq Armada M700 Notebook
Stuck in standby
Have you held down on the power button for more than 10 seconds to be sure the unit is off?
If not unplug power cord and remove battery if all else fails
Nov 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
The screem has broken and it can not power on
well you need to get a new LCD panel for your Armada M700. You could get something like this from eBay:
http://cgi.ebay.com/Compaq-Armada-M700-Laptop-For-Parts-or-Rebuild_W0QQitemZ360053106104QQihZ023QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(hurry....less than 8 hours left)
You could do this yourself if you are technically inclined.
May 23, 2008 | Compaq Armada M700 Notebook
My compaq armada m700 is having problem
this may be because the battery is dead so you may have to keep the charger attaached to the laptop for power. if this does not work then this means that the battery is no longer good so u will need to replace it.
please rate me. thank you,
Try to find a boot CD .Put that CD and try to start you computer and see it work or not.Incase it doesn't ,that mean you have a bad CDROM,you've to replace with the new one then.
takecare.
Apr 28, 2008 | Compaq Armada M700 Notebook
Compaq armada M700 power on problem
HMMMMMMMMMMM, SOUNDS LIKE SOMEONE NEEDS A INVERTER! YOU CAN BUY ONE OF THESE ONLINE, BUT UNLESS YOU KNOW HOW TO PUT ONE IN DON'T DO IT.
CHECK TO SEE IF THE DISPLAY WORKS BY PLUGGING A VGA CORD FROM YOUR NOTEBOOK TO YOUR MONITOR IF YOUR MONITOR SHOWS WHAT YOUR NOTEBOOK IS DISPLAYING, THEN IT'S YOUR INVERTER.
Dec 17, 2007 | Compaq Armada M700 Motherboard
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq Armada M700 Notebook Logo
293 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
