Question about Gateway GX7022E (RBGX7022E) PC Desktop
PC will not reboot.
When I power on the pc, I hear 3 beeps and pc doesn't reboot. The only thing that appears on scree is that monitor works
  • 1 more comment
  • ja li Apr 23, 2008
    my pc also cannot work but i think my motherboard is broken how can i test my motherboard please answer me
  • bonoba Apr 25, 2008
    I get the same thing, 3 beeps and then nothing. I have unplugged everything inside, replugged it in to make sure everything was tight, but to no avail.. same thing
  • Qaed Sep 15, 2008
    my pc was working perfectly, then i hear a continous beep as if some button was pressed for long time, i shut it down n now the keyboard & mouse wont work apart from every thing is fine.and also wen i try to restart pc it gives me 3-4 beeps my pc runs but my monitor doesnt start.
    now if then shut it off for 5-10secs and then starts but keyboard & mouse wont work.
    i am running ami bios
    xp sp2 home
    pls forgive for any mistakes, i m using on screen keyboard
    please help!!!
    Problem Solver:
  • 10 Answers
Thanks eagle I could finally get my server to start..
Posted on Oct 29, 2007
  • 4,889 Answers
Its a problem with your memory module(Did you install a new RAM?The beeps are caused by a mix of unregistered(64MB, 128MB) and registered memory modules(256 mb and above..Remove the unregistered memory modules and start..This problem also occurs if your memory is not seated properly in its slot..Just try pushing it in..
  • 1,006 Answers
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Posted on Oct 28, 2007
Computer wont turn on
you have to considered these things if can establish right
1. does any light indicator at the panel of your pc?
2. how about the fan in the PSU does it work?
3. also the processor fan it is working or get stuck up.
4. does the operating system boot up?.
5. do you hear any beep when rebooting and how many times.
if one of this doesn't work good then you can not turn on your pc.
Oct 12, 2012 | Compaq Evo D500 PC Desktop
Disassemble the machine completely and clean the Heatsink fan, blow away the dusts from the motherboard, if possible use brush to wipe away all the dusts. Reassemble it, but don't connect or install anything on the motherboard except the the power supply, the cpu with the heatsink and the system speaker. Now plug in the mouse, keyboard and the monitor (please connect the monitor on the integrated VGA port on the motherboard). Plug in the power chord on the back and short the two terminals of the power switch pins on the motherboard's Front Panel connectors, i.e PWR and GND with a screwdriver or with any metallic object you think is suitable (shown below):
Remember to switch on the mains switch (wall outlet connected to the power supply) and make sure both the power connectors on the mother is connected, i.e. 20 pins and 4 pins.
Check the status on the monitor and listen the beep codes (the system speaker is compulsory for this diagnosis). If you see anything on the display or if you could hear the beeps, note the beep sequence (let me know if it's not 2 beeps or 3 beeps, if it's 2 or 3 beeps, the proceed forward), Switch off the machine and install one memory stick (Ram) and reboot. If it was 2 or 3 beeps, then you should no longer hear them, if you still hear the same beeps, then try with another Ram on another SIM bank(s) [Ram slot] after the machine is put Off and boot again.
If you don't hear anything or you don't see anything on the monitor, then your motherboard is bad or perhaps the integrated video card is dead or it could be the BIOS chip itself. I would suggest you to replace it, as it's not worth repair. Buying a new one will cost you less then repairing this motherboard under such circumstances.
If you see or the beeps continues, try with another working Ram, it should definitely work if the Memory module on the motherboard is still working, otherwise.. I would again recommend you to replace it.
Well, in case if it's successfully booted or the display is ok, then proceed forward by installing the component one by one and reboot everytime you install a component or plug in connector (s). You'll be able to find out the culprit, whether the hdd, or the Dvd/Cd drive or the front panel switches or others.... Will need to replace or will need to repair.
Please update so that I will be able to assist you further.
Good luck.
Thanks for using FixYa.
Nov 10, 2010 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
It had been quite a while since I turn on my compaq presario 7204APr. And when it turned it on, there is no image appear on my monitor screen. How can I fix it?
Desktop PCs have separate power buttons for the monitor and the desktop component.
1. Make sure both items are turned on.
2. Make sure the cable from the Computer to the monitor is connected securely.
3. Are there lights on the monitor? Are they Green?
If they are amber the connection is not solid or the Video Card is bad.
Are there lights on the desktop PC? Are they blinking? If so the PC is working and the video is not. Check the connections and monitor power.
4. When you turn on the PC do you hear noise? If yes, the PC is working.
Beeps will sound if the video, memory or keyboard is not working.
After you check these things, reply to let us know if it is working or not.
Sep 10, 2010 | Compaq Presario 7000Z PC Desktop
Dell XPS 700 Black Screen, No Bios, Post error 1 2 3.
could be the cpu, its prolly the only thing you havent tested. or the power supply.
Mar 11, 2009 | Dell Computers & Internet
Data is not sent to the monitor
The first thing to do is to pay attention for "beep" when your press the power button (or the reset button) to turn the computer on or reboot it. The beeps that a PC makes tells you a lot about the state of your computer. I couldn't quote for you the exact beeps to listen for, but your manual for your motherboard may tell you. Different beep pattersn tell you what is wrong with a computer.
I think for many common motherboards it is something like 4 beeps to tell you the graphics card has failed. Don't quote me, but that is at least along the lines of how it works if not the exact number.
If you're getting no display after starting your computer make sure you hear one beep. Then, listen for other activity. If you're computer has a floppy drive, listen for the 'floppy seek'. Otherwise, listen for hard drive activity. If it sounds as though there's activity along those lines but still no signal/display on the monitor perhaps check the cable between your PC and the monitor. Never hurts to just make sure the monitor is turned on of course.
If your monitor is on, and the cables are connected securely I wold restart the computer again and check for the beeps. I would be certain to count them and check the manual. Your graphics card may have failed if you hear abnormal beeps (more than one as one is usually the healthy indicator). If you hear no beeps then the PC is not even getting in as far as testing it's devices and could quite possibly be a motherboard failure.
Dec 19, 2008 | Dell OptiPlex GX110 PC Desktop
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
PC will not reboot.
Either something has wiped out your operating system and you need to reformat the hard drive and reinstall it, or your hard drive went Since it worked fine the day before and just did this right away, my guess it that your hard drive went bad. But you can try both options though. Hope this helps.
Sep 13, 2008 | IBM ThinkPad T30 2366 Notebook
Medion Motherboard
if you cannot reach the BIOS settings screen at power-up, then try another known-good is likely dead.
Jul 05, 2007 | Medion (MT8381) (40004683) Motherboard
Gateway GX7022E (RBGX7022E) PC Desktop Logo
823 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
