Question about HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 paper jam.
I am trying to get an online copy of the owner's manual. Since the manual is
about 70 pages long, I loaded extra paper. I got a paper jam and don't know
how to clear it. It was because of not having the manual that I was trying to
print a copy. While trying to clear the jam I unfortunately pulled on the paper
and it came out, but now it doesn't work at all. Please advise. Del Murray.
  • 4 more comments
  • Anonymous Nov 20, 2007
    turns on and will make copies, but will not print paper jam
  • Anonymous Dec 07, 2007
    I was printing and the paper did not came out and a message pop out in my computer that said paper jam but the thing is that I don't know how to fix it. how can I fix this?
  • needmyprint Jul 25, 2008
    Hope you can help. Printer will not print-paper starts to feed then gets stuck, check paper light flashes, check printer light flashes. I manual remove on paper jam by pulling.
  • sewist1 Oct 09, 2008
    I SEEM TO HAVE THE SAME PROBLEM. WHEN I GET A PAPER JAM ,I OPEN DOOR TO SEE WHERE THE JAM IS and nothing is there. I will say in the past I have pulled paper back out that was half way thru the print job that had stopped. What do I do now ??????
  • Desheri Nov 11, 2008
    I have the exact problem the printer attempted to print and then it completely stop printing the paper jam light started blinking and now it does absolutely nothing.
  • Anonymous Mar 19, 2014
    I don't know where to load plan paper for a document I'm trying to copy
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Does it turn on or doesnt pick up the paper?
Posted on Oct 29, 2007
My hp 1315 check paper is blinking
un clip the back door there might b a jam of paper that u cant see but printer can detect once u have done that u must !! pres enter 2 reset it after u have replaced the rear door of course
Sep 28, 2012 | HP PSC 1315 All-In-One InkJet Printer
My HP psc1315 will not turn on. Some of the
To be able to understand the problem, you should give extra info about the lights.
Please find the information below about the status lights that provide information about error conditions of your printer. But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HP PSC.
2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting.
Problem 1: “ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1: The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same.
Solution 1:
• Load paper, or remove thepaper jam.
• Change paper in paper tray to correct size.
• Change paper size on the computer software.
Then press On/ Resume to continue.
NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
Mar 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
Hp psc printer paper feed is jammed with an piece of paper.
The small gear located in the paper feed assambly is break or fail, need replacement parts to repair it.
May 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP 1310 All-in-One
check inside for little extra pieces of paper
Apr 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
471 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
