If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
I bought an Oster Golden A5 new in a pet store in 2000. It did not work reliably out of the box- needed constant tweaking of the blade tension screws. It sat on a shelf for 15 years while I paid for many grooming sessions. Over the years I would try to get it to work; in 2015, I bought a generic brand #5 blade from a beauty supply, and it refuses to cut no matter what I do. Today, I spent 40 bucks on an Andis #10 and low and behold it cuts like a dream. Went back to the store and bought a #5 FC and it also cuts like a dream. So all my troubles were caused by 2 blades that were defective right out of the box...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
This is from the Oster book: Changing Blades To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue. To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
These kinds of clippers are fussy about oiling and dirt. It is essential that the blades be spotless and well oiled FREQUENTLY. Oil after every haircut always. Also, if there is not enough tension on the blades, the hair will slip between the blade and blade guard, getting caught and damaging the blades. Blades should be screwed on tight. Also, it may be time to replace the blade if nothing else helps. These blades do not last very long in my experience especially if not carefully cleaned and oiled.
try running the blade for a bit keep lubricating in between the blades its important to oil your blades during and after use to avoid rust build up on the cutting surfaces. Also just make sure the blade is engaging onto the clippers ok.
