Question about Harman Kardon AVR 25 MKII
No sound? i recently got this harmon kardon avr 25 from a friend who said it worked perfectly, when i hooked it up to brand new speakers i got no sound, no matter the input. no tuner, no phono...nothing. when i put in headphones and turn the volume to it's max i can barely hear a whisper but that's all the sound i've ever gotten from it....any ideas?
Yeah actually the prein jumpers were the problem...they had worn out....one of those "could have kicked myself" things....thanks for the help tho
Posted on Feb 21, 2008
  • 1,512 Answers
Hi Sicarius
I know it sounds dumb to ask these questions as you may or may not have already, but have you checked that any tape monitors are turned on. Another thing to check is that the "prein preout" jumpers are in place on the rear of the unit. If they are not there, just use a spare rca lead to jumper them. Let me know how you got on. Good luck
regards
Graeme
Posted on Feb 18, 2008
2 Suggested Answers
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
No sound from tv to speakers
i assume you are hooking up from tv to receiver with an optical cable? Check the settings on your tv. Most tv's have a setting to turn on/off the optical audio output
Apr 21, 2014 | Harmon Kardon Harman Kardon Avr-20 Ii...
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
My receiver doesn't have a dedicated subwoofer output, can I still hook up a subwoofer? I have a harmon kardon avr 25
That would depend mostly on your subwoofer. There are some that slave off the front left and right speaker outputs and still pass the amp's power to the Front Speakers. That would be the only way that would ensure volume control.
Otherwise you have to feed a self-powered sub from the Tape Outs but that won't allow volume control from the H-K.
May 29, 2010 | Harman Kardon AVR 25 MKII
I have a Harmon Kardon-AVR 320, DVD 25, PA 2000. I can't get any sound with when trying to watch a DVD. I've tried every setting on each system. The L and R speaker light blink on the DVD setting. The...
We have this same problem We had friend visiting; he pushed a button and we've lost sound but only on the dvd. I've tried every setting I can think of, but can't get sound. Did you find a solution?
Dec 27, 2009 | Harman Kardon AVR 320 Receiver
Harmon Kardon AVR 230 produces no sound and no monitor out.
you do not have +17v and -17v on transformer board the top two fusible resistors are blown and the cap between them needs to be replaced as this cap probably shorted and caused resistors to blow. easy fix
Jun 04, 2009 | Harman Kardon AVR 230 6.1 Channels...
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Harmon kardon avr 25 ii
I upgraded my HK AVR 20II and ran into the same problem when I tried to hook the old unit up out in my garage.
Luckily I remember that on the rear there is a pre-out RCA port (L/R) and a Main-In port that are intended to be to/from an equalizer/amplifier. These come jumpered out of the box, but I had been using an equalizer so the jumpers were long lost.
Assuming you also have no amp/eq you are using, just connect the Pre-Out to the Main-In using a standard M/M RCA cable and you will be in business. (turn the volume down first!)
Good luck.
Jan 02, 2008 | Harman Kardon AVR 25 MKII
Harmon kardon avr 25 II
Oct 28, 2007 | Harman Kardon AVR 25 MKII
304 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
