SanDisk Sansa E280 MP3 Player
Problem for SanDisk Sansa E280 MP3 Player
My Sansa E280 has garbled sound in playback. The
By mmccleskey on Jun 11, 2009
My Sansa E280 has garbled sound in playback. The lead vocalist sounds partially muted. Other instruments and background vocals sound fine. This happens on all songs. Like anything in the very center of the stereo spread is being cancelled out. Help??
Solution #1
posted on Nov 02, 2009
Not Rated)
bobfisher118
Rank: Apprentice
Rating: 0%, 0 votes
I have experienced the same problem with my sansa and taken it apart to see what the issue is. It has to do with the connection of the audio port on the board. Its not making a clean connection on mine, wiggling the cord or flexing the board in different ways made it sound right or recreated that crappy garbled sound. I still haven't found out how to permanently fix it, but taking it apart and tweaking mine has helped quite a bit getting it right.
I suggest you crack yours open and try and tweak it, or sell it.
To pop it open, if you haven't already ripped off the front cover. You'll need a very small precision Phillips or flat head(I used a flat head, can't find my Philips) On the bottom right, opposite of the headphone, there is a hole, stick the screw driver in there and remove the rubber cover, then remove the screw behind it. Now there is a locking mechanism behind the screw, you need a needle or paperclip thin enough to fit in the hole. Gab it in hard and then pry the case opfrom the bottom, leaving the top like a hing. There are 6 clips on the inside that will resist the opening, and if you have kept pressure on the paper clip, you won't have broken the anchoring clip by the bottom left. There are 5 other screws that have to be removed to get the board out to look at both sides.
Two screws on the LCD display, one above and one to the right. There are 2 screws on the board. both near the bottom,one on the right and one on the left. and the last screw is hidden in the bottom left corner of the display.
You can remove the battery and the screen if you like. If you remove the screen and reconnect, you may have to do a full shutdown(Hold down the off/on button) and start up of the unit for it to display correctly again.
When you have it all apart, have it play some of your music and prod the jack linkup. Try and figure out what makes it sound awesome and what directions make it sound like ****. Put some pressure on the board and remember what directions of flex make it sound good. Going to a FM station also works, if your headphones don't make a good connection, you can not get reception. Good luck!
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa E280 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa E280 MP3 Player
Do you recommend SanDisk Sansa E280 MP3 Player?
Answer
Answer
Sansa e280 quit working. The blue light on the dial comes on, but nothing on the screen. I have... (More)
Answer
There is an error message reading "Bad Track" when I try to play some music. Then after I... (More)
Answer
all of a sudden my 280 now takes 3 to 4 minutes to start up. it used to take only 20 seconds.
Answer
how do i get my mrdia player to detect my zune
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For SanDisk Sansa E280 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 766
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
