Copiers
Problem for Copiers
Generic problem for all Copiers
Monroe 946 copier
By varmaduke on Oct 28, 2007
copies are coming out streaked I was told it needed a new drum cleaning blade how do u change it
Best Solution
posted on Oct 29, 2007
Helpful)
CopierOne
Rank: Wiz
Rating: 91%, 49 votes
The drum cleaning blade is located in the drum unit and is very much like a windshield wiper blade on your car and even has the same function. It cleans the drum of toner residue after each copy is made. A positive test to see if the drum blade is worn is to make two or three copies of an original and if the streaks are worse on the second copy and worse still on the third copy, then you can be fairly certain that your drum blade is bad and needs changing. Not a simple task, probably best left to a technician. You can do some serious damage to the drum if you're not careful. If the test that I described indicated that the drum blade isn't bad, then the next most common problem is a worn heat roller in the fuser. Not an easy thing to replace either. You can check this by making a copy and stop the machine just as the copy just reaches the exit rollers of the machine. After removing the copy, you can see that part of the copy has been through the fuser, the part of the machine that gets hot, and part has not reached the fuser. If the lines are on the copy that has passed through the fuser, but aren't there on the part of the copy that hasn't reached the fuser, then you can be sure that the lines are caused by the fuser roller.
Let me know if this helps.
Aloha,
Bill Monroe
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
i am having a sharp ar201 after changing the tuner , the display dash board is display error code ,... (More)
Answer
I'm setting up a 8830 and a 7356. The scanner says ready but when I put in the paper it says not... (More)
Answer
new cartridges installed in hp 290 color copier. can not print allignment page. cleaned cartridges... (More)
Answer
Machine Error 7A and the machine say unplug machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 753
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
