Question about Sanyo Katana SCP-6600 Cellular Phone
Water damage... hopefully fixable :( i hate hot tubs...
I was at a party and went to the hot tub, i kept my phone with my just in case my parents needed to reach me. i put it on the outside wall of the jacuzzi and thought it would be fine... until my 300 pound friend big will got in... the hot tub over flowed and drowned my phone... now the screens are both black, it won't charge (well at least it doesnt show it... because the screens are black) and i cant turn it back on...
i have already opened the phone up, taken out the battery, and let it try for about 20 hours... and it still wont work...
any help? do i just need a new battery? or is the only way a new phone...
what a dumb way to lose a 275 dollar phone...
HELP >.<
  • Meesha Albano Sep 27, 2008
    at a party forgot i had the phone on me in the jicuzzi took it out imedately put it to the side someone got in drown my phone i took it apart imedaely patted it dry with a towel dryed it wiht a hair dyer but on low and cool from a distance put the battery in and it vibrated so i took it out imedately then i kept it apart for the night put the battery back in the screne was white no vibrating red light on front katana on front took the battery out its sitting under a lamp now taken apart so i'm hoping its gonna be better the next time i put it togeather... any other solutions?
Thats why you buy insurance.
Posted on Nov 13, 2007
We keep getting a brow film around the edge of the hot tub.
That is normally iron in your water. It often happens in cottages that are beside lakes and have bore wells. In your case with a hot tub, it is a residue that comes off the people using it!
Body Chemicals - This is the most common cause of film in hot tubs. It's caused by deodorants, hair products, perfumes, and lotions. ... Poor Water Chemistry - Water with improper pH levels and bad calcium levels can cause buildup and lead to film floating on the water or collecting on the sides of the hot tub.Apr 7, 2016
Foam And Brown Film - Hot Tub Water Chemistry - Pool and Spa Forum
https://www.poolspaforum.com > Pool/Spa Water Care > Hot Tub Water Chemistry Oct 24, 2008 - 11 posts - ‎6 authors
Hi all New to the Hot Tub World New to the forum. ... The reason the film is brown is iron in the water absorbs into it. .... to realize that foam downs are bandaid fixes and don't do anything to eliminate the cause of the foam.
Use CLR.
CLR Calcium Lime Rust Remover
what causes brown film in hot tub Google Search
Jun 23, 2018 | Pool & Spa
Morgan hot tub
I found the drain snakes very helpful to unclog a drain even it is a bathtub. Dran snake found both hand cranked and power cranked. for home use, the hand crank is enough but for professional plumbing power cranked drank snake is best.
Learn more from here -
https://www.toolsfreak.com/best-drain-snake/
Jun 30, 2014 | Pool & Spa
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 05, 2013 | Maax Crescendo - 100085-000 Bathtub
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Inner tub broke away from outer tub casing
Time for the dump. Probably need a new tub lock nut but there may be more damage to the transmission or tub seal which will leak water and it may not be worth the $100 service call for a Tech to tell you you need a new washer. Good time to buy appliances right now, try to get free installation!
Jul 21, 2009 | Frigidaire FWS1339A Top Load Washer
I went in the hot tub with my phone..i have no ins any idea's to get it to work?
u can try to dry these phones off with cool air (npot hot) and all the rest, but if water molecules remain it may work for a biot n then corrode and not work again. try it though, but its often in vain.
May 04, 2009 | Cell Phones
Cell phone dropped in water - red dot showing - options?
you don't need to actually drop your phone in water for there to be water damage.
simple things like having your phone in the rain, in the bathroom while you shower, around a hot tub, or possibly even if it's really humid outside can set this water damage sensor off.
it just gives phone companies more ways to void your warranty.
hope this helped.
Sep 08, 2008 | Cell Phones
Sanyo Katana SCP-6600 Cellular Phone Logo
105 people viewed this question
Top Sanyo Cell Phones Experts
270rexton
270rexton
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Steve Allison
Steve Allison
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
