Sony ke32ts2u I have 2 of these units and both have the exact same problem, the power supply has burnt out, what do you suggest replace both power supplies or is this a common problem in these units?
  • 8 more comments
  • joeygreen007 Oct 09, 2008
    I have an olevia 32 in. We were watching the TV left the room and came pack and the screen was scrambled. We turned it off and would not come back on. The blue light comes on with power, but no picture
  • xpladox Nov 02, 2008
    Sounds similar to my TV's problem. Blue light activates when I plug TV in but the TV will not turn on when I push the button, not with the remote either.
    Is this the power supply?
  • jmraymond7 Feb 14, 2009
    My TV tries to come on but just a blue screen comes on for a short period of time without a picture
  • ROBeaulieu Mar 03, 2009
    Picture went dead, told the PS had failed.
  • RUSHING01 Mar 11, 2009
    I have same issues picture only comes on for 3 seconds and goes off was told to do alot of things found out short in power supply where can i get a new or used one for parts
    Nec Px-42vp4a
  • Anonymous Mar 26, 2009
    same as everyone else.
  • Anonymous Apr 16, 2009
  • Anonymous Apr 17, 2009
    i have the same problem with my 42 inch all of a sudden while it was on the t.v just shut off. Now i do not get any power to it. What should i do?
  • Anonymous Apr 29, 2009
    Same problem, TV is only 2 yrs old - is this normal ? IT is a Sharp lc15av7u
  • lisa0930mich Apr 29, 2009
    have same issues picture only comes on for 3 seconds and goes off Sharp 15' lc15av7u
  • 176 Answers
SOURCE: Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
Posted on Apr 16, 2008
SOURCE: Sony ICF-CD855V clock radio no power
Transformer wire that connected to one of the AC terminals was broken. Soldered a jumper wire between the terminal and the transformer. The most difficult part was finding a tool to remove the 3 triangle headed screws from the power supply, ended up making my own tool.
Posted on Dec 31, 2008
  • 4234 Answers
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Posted on Jan 21, 2009
  • 34 Answers
SOURCE: TV power supply burnt out
If you can read the numbers on the power board, sometimes really obscure and have the model number of your tv, you can contact the manufacturer and see if you can buy the power board directly. If not, contact a local tv shop and read the part number off to the tech and give him the make and model and see if he can locate it for ya. some of these parts have lifetime warranties so check with your manufacturer. hope this helps, j
Posted on Apr 08, 2009
  • 17 Answers
SOURCE: Sony PFM /42b1 NO POWER has power supplies for a reasonable price all you need is the part number off the board. Hope it helps!
Posted on May 08, 2009
I have a sony kdl-52v4100 tv. It had a power surge and now blinks 2 times. I changed the power supply with a known working one and it burnt it up. I changed the power supply again and the bu main boar
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 03, 2017 | Sony Bravia V-Series KDL-52V4100 LCD TV
Loud bang from system.Unit starts immediately power is supplied.Power switch does nothing.H/Drive and players run.No video ( card OK ) checked with another card. Can the problem be motherboard?
The load bang is most like an exploding capacitor in the switch mode power supply, especially if there is a burnt electrical smell from the power supply.
I suggest you borrow a switch mode power supply, remove the old power supply and install the replacement power supply. make sure it has the same or larger wattage unit.
If the computer still does not boot up then the exploding power supply has damaged the motherboard, and you need to replace then motherboard too. This may not be a cost effective solution.
This is an opportunity to get a new and better computer.
May 16, 2011 | Computers & Internet
I got logitech speakers X-230 M/N: S-0123A that need ac110-120v- 60 Hz from USA and by mistake plugged it into ac 220 v that is standard in new delhi. there was a spark and smoke from the woofer unit, and...
You have damaged the power supply unit and this would have caused some failures on the power supply and sometimes on the drivers.
So first of all please check the power supply unit, alternatively the DC power required can be supplied by incorporating a new power supply with the same rating but working on 220volt.
repairing the 110 volt supply is no good as you will need again a step down to work , so I suggest this change.
Feb 25, 2011 | Office Equipment & Supplies
Does the above have a fuse inside the case / AC power supply? PC has suddenly developed a start up problem - power on light flashes once for a split second then power (appears to) cut off. Any idea(s) as...
yes you will find 2 or 3 fuses inside the power supply, see and smell for some burnt parts, like trancistors it will be 3 or 5 legged device with a metal back.
if some thing is burnt do not replace fuse the power supply needs to replaced.
beware replace fuse only if no parts are burnt, do not test in open state to avoid electrical shock.
Dec 23, 2010 | Sony VAIO PCV-W30 PC Desktop
Sony tv model kv 32hs420 turn on hear relay kick then shutdown no picture no sound and no red light I replaced 2 IC MCZ3001d
You may have a problem with the capacitor. Normally the ones on the power supply circuit are the first ones to go out. Have it inspected for leaks or swelling. Also check out the unit for burnt resistors.
Dec 10, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
I have given additional ac supply to it something went wrong now it is not working
Rohit, With additional AC supply you have most likely burnt the amplifier. But there may still be hope if only the power supply unit of the device has been burnt. Open up the rear panel of the unit that has the power cord coming into and look for burnt and burst components. The whole modules would have to be replaced with exactly the same specs.Do it. if you feel that you cant handle it then go to the service center of the brand that you have.
Nov 13, 2009 | Creative Labs Inspire 2500 Computer...
My Acer Aspire X1700 power supply burnt out....
The manufacturer is Delta Electronics, Inc.
Their website is down.
However, I did find it :c) Took awhile...
Jun 27, 2009 | Sony VAIO PCV-RS724G PC Desktop
Power on but no led display
"Power board:
The power supply is the main culprit for most of the TA-E9000ES failures. Symptoms of this are no sound and a very dim or no display. Apparently the power board has several weaknesses which have caused Sony to supply a modified version in later production units. The circuit around transistors Q108 and Q109 are prone to oscillation, which will cause one or both transistors to break down, as well as resistor R124. This resistor is originally a surface mounted device capable of 1/10 watts of heat dissipation. The modification suggested by Sony is to replace this 4.7 k ohm resistor with a 1 watt rated version. Also, to prevent further oscillations a 100 pF capacitor is added in parallell with R153. (Some suggests that also transistor Q110 is a candidate for replacement.) The US issued service bulletin from Sony suggest that this fault may occur with units having a serial number in the range 800001 - 802746.
Serial numbers 80#### are for the US/Canadian version.
Serial numbers 50#### are for the european version."
Aug 26, 2008 | Sony TA-E9000ES Amplifier
Will not turn on
It sounds like you have a power supply problem. I would suggest that if you are going to effect repairs on this unit yourself you get a schematic of the set and use a multimeter to test the power supply levels. This is good for a starting point, if you need any other assitance you can contact me or any of the FixYa experts to aid in additional troubleshooting.
Apr 30, 2007 | Polaroid FLM-3201 Television
Televison & Video Logo
1,640 people viewed this question
Top Televison & Video Experts
