SOURCE: ilo 32" SDTV
I suggest that you get intouch with the Ilo manufacturer for a new owners manuel.
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
SOURCE: TV ILO 26HD
Hi, We are a tv shop in cin ohio. A client of ours had same problem with his set. The part number they gave us for ILO-26HD is e22556. It is board and must be replaced and is reasonably priced. Call this number 909-392-5583 x130 they were really helpful.
SOURCE: ilo TV, universal remote
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
SOURCE: ilo tv won't turn on at monitor/set or via remote
Bad parts on your power supply board need testing and replacing....when you get the tv serviced be sure to tell the technician to install higher quality parts. ILO tends to use low-grade components that warp very quickly as their not designed to handle excessive heat for long periods of time. This is a very common problem with ILO and Akai tv's....
if the tv is under warranty take it back...
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
