Connecting 2 stereo amplifiers using one as a preamp and the other as a booster
How do I interconnect two amplifiers to use one as a preamp and one as a booster for my rear speakers? I have a Pioneer VSX 454 with surround sound. I want to hook up a Marantz 1060 to boost the sound to my rear speakers.
I would take from the tape out of the pioneer and feed into the aux input of the marantz you will then have to adjust the volume levels on each amp as required
Posted on Oct 29, 2007
SOURCE:
How do hook up an amplifier and subwoofer to my car stereo?
If your stereo has preamp outputs, I would recommend connecting those to the input RCA connections on the amplifier. The connection from the amplifier to the subs is dependent on the capability of the amp and the impedance/power level of the sub.
Aug 31, 2014 | Car Audio & Video
I am trying to bridge two macrotechs 1200 and I am getting a loud huming noise . No sound. Just that noise. When I run them in stereo mode they work perfectly fine. What causes that?
Let's review the setup procedure and precautions. This is for bridging the amplifiers within a single box.
  • The mono-stereo-bridge switch must be in bridge position
  • The input signal must be connected only to Channel 1. NOTHING should be connected to Channel 2.
  • The Channel 2 level control should be turned all the way down. Turning it up will amplify common-mode noise.
  • The + speaker terminal is connected to the red binding post for Channel 1 and the - speaker terminal is connected to the red binding post for Channel 2. Neither side of the load should be grounded.
  • There are no connections to the black binding posts. They should not be grounded or shorted together.
It does not seem practical to bridge or parallel two MT 1200 boxes; it would be very difficult to get the levels and offsets precisely matched. If they aren't matched, you will get oscillations or common-mode amplification - that is your humming noise.The bridging switch makes six changes to the circuitry to get the amplifiers properly interconnected in one box so this won't happen in the recommended configuration.
Jun 20, 2011 | Crown MT 1200 2-Channel Amplifier
How do i connect a behringer ep 4000 to a numark x6 digital mixer, i.e what type of lead do i need??
Alwaays use balanced lines. The amp will accept either XLR or TRS at that end. The Numark accepts 1/4 TRS. You should probably get TRS to TRS cables... While these look a lot like "stereo" 1/4 inch cablles they are NOT. Thesee need to be intended for balanced interconnection. They will be twisted pair within a shield. Here is an example:
http://accessories.musiciansfriend.com/product/Monster-Cable-Studio-Link-500-Interconnect-TRS-M-TRS-M?sku=331684
Apr 26, 2011 | Behringer EuroPower EP4000 2Channel...
I just got one what is it an how does it work an how do i hook it up?
2 channel power amp
you will need additional equipment for this beast to work right.
1. you need a pre-amp, all audio connections go into the preamp which control sorces, volm, bass and treble.
2. out from the preamp into the power amp and out to your speakers
3. you can freak it if you have an 1/8" stereo to RCA stereo plug in this caee you can play your ipod, phone or mp3 player thru this amp using your input device (ipod, phone or mp3 player ) like a preamp to control volm, bass and treble.
Feb 21, 2011 | Sharp SX9860 2-Channel Amplifier
Connecting laptop computer to rx-v395 yamaha amplfier
Hi, yes it is possibe, but you are going to have to buy a stereo 2.5mm jack to 2 phono lead. Connect to headphone socket on laptop and the other to a line input on amplifier and adjust setting to suit.
I hope this helps, if you need more info, I will help.
Regards - Anthony
Feb 06, 2010 | Marantz MA-9S1 2-Channel Amplifier
I am playing my stereo with the su-g95 amplifier what can i do to play all 4 speakers at the same time.
first dose your amp have 2 or 4 outputs if 4 outputs you have to have 4 speakers ,and connect them on your amp speaker output is that so hard to do ....
Nov 17, 2009 | Technics SUV500 2-Channel Amplifier
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Center channel speaker
Is the amp already used for L R? If so, you either need another amp for center, or set your Sony for stereo mix down. I have mixed the center channel into my main LR in the past and found there were terrible phase cancellations, so I suggest you switch to Stereo, or use a separate amp.
Regards
Peet
Jan 13, 2008 | AudioSource Amp Four 2-Channel Amplifier
710 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
