Question about Mitsubishi WD-65C9 65" DLP HDTV
Wd-65c9 stuck on title screen does not power down
4 Suggested Answers
SOURCE:
Ecollier2012
  • 3459 Answers
SOURCE: i need the diagram schematics on a MITSUBISHI WD-65C9 television
check our site www,tvrepairkits.com - may have one
Posted on Apr 02, 2012
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi TV model wd-65c9 turns itself off how
l would first look to front of set when this happens---set has indicator lights that will blink (each is explained in the owner manual)
Could be Lamp, Ballast, power supply etc.
Posted on May 01, 2012
  • 28 Answers
SOURCE: mitsubishi model wd=65c9 when turned on green light blinks repeatably sound comes on but no picture
The bulb that lights your picture is burned out. Buy a new warranted bulb from shopjimmy.com $85 with the housing. You can replace this yourself in 5 minutes. Shop jimmy has a video showing replacement. Remove 2 screws that hold the housing in place, slide the bulb out and slide the new bulb with housing in and replace the 2 screws. Plug in and enjoy your tv.
Posted on Feb 25, 2013
White dots on the sreen
Sounds like a failing DLP chip.
Apr 02, 2014 | Mitsubishi WD-65C9 65" DLP HDTV
White specs on screen 2009 wd-65c9
Its a DLP so if white dots have started to appear and or increase in number the problem is in the optical light engine this set uses.
Nov 05, 2012 | Televison & Video
My WD-65c9 boots to welcome screen then shuts down with a flashing red LED.
42 is an error code for faulty "Lamp Sirocco Fan" part no. 299P321010. You have to replaced it with new one. I've saw it at shopjimmy.com ( http://www.shopjimmy.com/mitsubishi-299p321010-fan.htm )
Dec 15, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
I HAVE A MITSUBISHI MODEL 65C9 THAT WHEN I PRESS POWER BUTTON AND GREEN LIGHT BLINKS STARTS TO LOAD UP AND THEN TURNS OFF WHAT IS THE PROBLEM?
You need to replace the main board, call Mitsubishi help line, they did not charge me a dime (If your TV is less than Yr old)
May 17, 2010 | Mitsubishi WD-65C9 65" DLP HDTV
Mitsubishi WD-65C9 65" DLP HDTV Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
