What kind of oil? silicone?
SOURCE: HOW DO YOU ADJUST THE BELT ON A PROFORM 725 SPACE
Use the allen wrench to loosen side that is touching. 1st locate on the end of the treadmill 2 slots, 1 on each side and place the allen wrench into the slot. turn anticlock wise 1/4 turn. Turn on treadmill at 3 to 4 miles per hour (not standing on it) and make ajustments in 1/4 turns until belt gets centered and snug. When you have it centered you may ahve to tighten or loosen it in case it is slipping when you are running on it. When you ajust it when centered you should do this in 1/4 turns on both sides to keep it centered. If this doesnt fix the problem I suggest that you may have some other problem or are not capable of reolving this problem on your own. Ask another friend for there opinion if this fails.
SOURCE: can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
