Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi wt-42311 tv wont stay on
Turn set on and power light comes on for about 5 seconds and goes off. no pic or sound. I held the menu and input buttons and it flashes twice and keeps on doing that any help is appreciated.
  • 2 more comments
  • gentrytw Nov 01, 2007
    Same. Help!
  • styx06999 Nov 04, 2007
    I have the same problem exactly, but mine only stays on 2 seconds.
  • Anonymous Dec 12, 2007
    quiero prender el tv pero arranca 2 segundos y no prende
  • dinag Dec 14, 2007
    I have the same problem, Is it worth getting fixed
    President:
  • 4,402 Answers
Convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 15, 2007
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
May 31, 2011 | Mitsubishi WT-42311 42" Rear Projection...
TV Doesn't stay on...
HI
base in your comments in your TV you have defective power oscillation circuit! and need to diagnose your TV with a qualified technician! now if you have knowlegde in electronic trouble shooting i can give you the method to fixed your TV. Thanks in Advance!!!
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
When i press power the timer light flashes and the T.V. turns on and right back off.
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Oct 03, 2010 | Mitsubishi WT-42311 42" Rear Projection...
What is the going price for a power supply on this brand T.V. and how can I be sure its the power supply?
If the power light comes on when you attempt to turn the set on and the goes off, do this:
On the front of the set press and hold both the Menu and Input buttons for at least 5 seconds and then release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code and I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 24, 2010 | Mitsubishi WT-42311 42" Rear Projection...
It turns on for only 3 seconds and goes off on its own
Please do the self check this model has.
turn set on and when power light goes off:
On the front of the set press and hold BOTH Menu and Input (device) for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code like: 2 blinks, a pause and 2, blinks. It will repeat the error code at least 5 times. To get it to repeat you have to unplug the set and plug it back in and try to turn it on again.
Let me know what error code you find and I will tell you what it means.
SD TECH
Jan 27, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I have a Mitsubishi Model WT42311 Tv . It will not stay on . When you press the power button it tries to come on but turns itself off. Do you have any suggestions?
Yes, do the self check that this set has.
When you try to turn it on and the power light goes off:
On the front of the set press and hold both MENU and DEVICE (OR INPUT) for 5 seconds and release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks---it will repeat the code at least 5 times.
Let me know what code you find and I will tell you what it means and what may have to be done.
2,2 is the most common and the least expensive to fix.
If this information helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 11, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Will not stay on
Do you have any sound? If not, open the panel and press the menu and input buttons and the same time, count to three and then there will be a code flashed,  it will flash a t least once followed by a pause and then a nother set of flashes let me know
Sep 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
200 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
