Question about Conair Gs4 Iron
Conair GS4 Steamer
I have lost my manual and I have noticed a substance in the inside/bottom of my GS4 steamer. It kind of resembles a mold substance but I dont think its mold. I can't find out how to open up the steamer to clean it out. How do I clean my GS4 Conair Steamer?
  • 6 more comments
  • idontb Nov 19, 2007
    my conair upright stop working. I think its clogged because the red light cames on and will not go off.
  • Anonymous Mar 02, 2008
    I have exactly the same problem...that stuff inside looks very gross and I have clothes that need steaming piling up.
  • Anonymous Apr 08, 2008
    Same problem - lost the manual over the years and now can't figure out how to get the gross stuff out of the tank. I think this is why the nozzle is spitting so much water. Does ANYONE know how to fix this thing? Might just invest in a different one.
  • bambi99 Jul 30, 2008
    I recently bought a compact conair fabric steamer and can't find the directions. is there anywhere to get another user manual/directions?
  • Anonymous Aug 27, 2008
    Need operating instructions. none in box
  • promised Nov 15, 2008
    A reddish brown substance is in and coming out of the steamer where the overflow valve is. How do I clean/fis this?
  • Anonymous Mar 26, 2014
    NOT WORKING, NO STEAM
  • Anonymous Mar 28, 2014
    the steam doesn't come on
You can find the instruction booklet at Conair.com...Seach "clothes steamer" and click on you model. You will find all the specs and the booklet at the bottom so you can view it. Problem is that the instructions are just that..Instructions! No troubleshooting of any sort. I had a mildew build up in mine too...I just filled it and turned it on to loosen it up and emptied it. This took many times. Your can also use a bit of vinegar with your water but make sure you boil it all out before steaming your clothes again. A good way to avoid the mildew is to empty the holding tank after every use.
Posted on May 18, 2009
Conair GS4 Steamer - faa3e02.jpgThis is from conair instructions included with steamer, finally found it, hope it helps some!
Posted on Jun 28, 2008
That stuff in there is calcium buildup from the water to clean it out rinse with mild soap and water
if problem is bad then you can use a little bit of vinegar and baking soda solution(baking soda optional) just like you clean the calcium out of the coffee maker
Posted on Apr 13, 2008
How do I fill the GS4 steamer?
http://www.conair.com/instruction_booklets/10pa117459_gsS4_ib%5B1%5D.pdf
Oct 19, 2014 | Conair Compact Fabric Steamer GS4
Rowenta 1500 garmet steamer no longer makes steam
Someone else had this fix and it worked for me: (yay!)
*Remove water tank and collapse the hanger bar.
*Remove two screws at base of hose and work the hose off. It will come out.
*Unplug unit and hold over your kitchen sink with the hose inlet pointing into the sink.
* use your kitchen sink sprayer to forcefully spray water into this hole and it will come back out again releasing the gunk that has been stopping up the unit.
* for good measure, I also used the sink sprayer to flush out the hose.
Put everything back together. And make sure it is dry before you plug it in.
VOILA!!! WORKS GOOD AS NEW. HAPPINESS!
Jan 10, 2014 | Conair Gs4 Iron
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Re Conair garment steamer ctx12c
I bought this model from Costco and followed the instructions and tried using the picture on the box. You may have trouble, or at least be confused, if you try to attach like the picture on the package because the hose in the box is not exactly as pictured.  The hose you get does not have that extra ribbed part around the end that attaches to the console.  Therefore try the other end and you should be able to attach.  Once you figure that out make sure you "lock" the hose into place.  If not steam will escape from the loose installation and may scald you if you reach down.
Oct 06, 2008 | Conair Compact Garment Steamer Iron
When using steam iron i am left with a puddle of water on the floor how do i control the amount of steam
I think is maybe the hose connections. You need to make sure both ends (by the T-nozzle and by the body of the steamer) are secure. You have to align the nozzle with the rod, and push down, and twist. Try watching instructions for connecting both ends on www.HandBookLive.com under appliances category. There are GS4 video instructions and GS10 (this one has just been posted yesterday)
hoe it helps. Otherwise I would return the steamer. Nowhere in the operating instructions does it say that you can control the amount of stream produced...
Laura
Sep 27, 2008 | Conair Compact Garment Steamer Iron
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Conair Gs4 Iron Logo
2,309 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
