Turntable will not turn due to broken drive belt. Is it possible to obtain and fit new drive belt?
Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
SOURCE: Belt broken; how do I fit in a new one?
I believe the platter simply lifts straight up off the spindle. Put the new belt on the platter and reinstall it. Then, working through the access hole in the platter, put the belt around the motor drive shaft. Rotate the platter a couple of revolutions to make sure everything's seated properly and you should be back to spinnin' the hits in no time!
SOURCE: Kenwood Trio Turntable belt broken.
I have them listed as item 250423608612 on Ebay .. softwaredivision
SOURCE: my prolectrix usb turntable won't play properly
i also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
