Connected line on 1/2 and still when i select line 2 there is no dial tone. if calls come in on line 2 it will ring, but when i answer there is no dial tone or connected call. please help solve this problem. thank you!
SOURCE: uniden tru448-2 rotary dial
You can download the manual from the link below: http://www.uniden.com/pdf/TRU448-2om.pdf To set tone dialing see picture below: Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones
in the house unplugged.
Thanks.
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
SOURCE: phones don't ring
Caller ID is a service that is provided by your telephone service provider and not the phone. If the phone company isn't sending your line Caller ID data, your phone won't display it. As for getting the handsets to ring, try pushing the volume up key while the handset is off, the more times you push the button, the louder the ring will get until you are at max ring volume. Also, some models have a "Do Not Disturb" feature which turns the ringer off. Without knowing which model phone you have I cannot tell you how to turn this feature on/off. but you can look it up in your manual online at http://www.uniden.com/index/manuals_results.cfm?cat=1
