Water got spilled on the screen. I wiped it off. But some got under and inside the screen. There was distortion so i turned it off for a day. But after finally turning the tv on I observed that there is slight discoloration in viewing and there's distortion in the picture. Also a part of the screen on the leftmost side is blank and even the back light is off in that part. Its Bad. do i need to get the screen replaced?
SOURCE: TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
SOURCE: water stain inside of screen glass
Yes, you can check with ctechnicians.com for instructions on disassembling.
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
SOURCE: Samsung 2006 56
Possibly a bad light tunnel assembly if the part is only a shadow effect. If not then probably a bad DMD board. The DMD board is part of the light engine but needs to be replaced by a technician.
