Question about Compaq Presario Notebook
Monitor problem I have small blue writing on my LCD screen, it appears to be some type of pattern. It's too small for me to read. At some point the characters turn into vertical lines. I can still read everything on the screen.
  • 3 more comments
  • Anonymous Nov 05, 2007
    I have a similar problem I have the vertical lines that go across the screen from the bottom and go about 1/2 way up to the top.
    THIS IS WITH THE NEW LCD SCREEN I RECENTLY GOT. It is for a GATEWAY SOLO 2100. The original screen went bad out of focus and of centered.
    The replacement screen I got was for the same notebook and is a new screen it still had the clear celaphane on it when I got it.
    The picture is good it is when I have the windows 98 screen and my desktop background that the lines appear and no matter how dark or light I make the screen they are still there. It boots up fine the black screen with the white lettering. It is when the colored screen of Windows 98 appears that the lines are there.
  • barbara Jan 27, 2008
    Monitor problems: HP Pavilion laptop zv6000, moderately used, 2 yrs old:
    first I had horizontal lines, which would disappear again after applying pressure to one side of the screen or by slightly changing the angle. (Slightly twisting pressure).
    Problem gradually worsened over several months. Now the lines are very close tiny vertical lines which don't go away with pressure, and can't use the laptop at all.
    I could do a minor fix myself, but if this sort of fix requires soldering, extra tools, dust-free environment, I need a recommendation for ship out + fix.
    Correction on symptoms:
    HP Pavilion zv6000 laptop display has very fine horizontal lines, a large foggy white vertical band down the middle, which takes up the middle third of the screen. Progressively worsened to the current status over several months.
  • 12xyz Aug 14, 2008
  • barbara May 11, 2010
    You posted info on this a couple of months ago. My monitor is doing exactly what you described.
    Is there anyway for me to fix this myself? If not, would you be able to recommend a route for getting it fixed? I hear going direct to HP is expensive.
I am seeing many people have these type of problem. Why did it happen? I have a couple of vertical line on my LCD. If I applied a little pressure to flex or twist in. It does go away. What does it mean? What is the cause? Is it repairable?
Posted on Apr 16, 2008
  • 90 Answers
Sounds like a bad lcd.... any time you get vertical or horizontal lines, usually, the lcd needs to be replaced.
If you flex the screen a little, does it change? Don't use alot of force, just grab the laptop lid from both side and tweak it a little to see if the lines change or go away.
What make and model is this?
Posted on Oct 29, 2007
Red blue and green patterning on the monitor
You can try switching out the VGA cable (the one with the blue connectors on each end). If this does not work, try a factory reset on your monitor.
Oct 15, 2012 | Dell Dimension E521 AMD Athlon 64 X2...
How do i connect the lcd to my computer
The monitor appears to be DVI capable, (White connector with a grid pattern). You will need to connect the monitor to the computer using a DVI cable (White connector with grid pattern and plus sign shape on one side). If your computer is not capable of connecting to a DVI monitor check to see if the monitor has a Blue VGA (Blue Zig Zag Openings) and connect it with a VGA cable. If your monitor only has the white DVI connector and your computer only has a Blue VGA connector you will need to go to the store (Best Buy, Walmart, Etc) to buy a small adapter that will convert DVI to VGA. If you ask someone for a DVI to VGA adapter they will know what you are talking about. I hope this helps.
Mar 14, 2011 | Sceptre MNTR SCPE|LCD19' 8MS DVI...
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Dell E176FP Monitor Stuck in diagnostic mode??
See if the set has some sort of reset button. If none do a hard reset on monitor to hopefully clear the cobwebs in monitor electronics and see what happens.
Mar 12, 2017 | Dell E176FP 17" LCD Monitor
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
ACER AL1716 acting up BAD!
Be more specific. I guess your monitor has inbuilt speakers which are making noise. If yes do come back for a solution.
Sep 30, 2007 | Acer AL1716 17" LCD Monitor
What is moir?? (red/blue stripes)
Sometimes odd stripes or colors will appear in a digital image, either from a high-end digital camera, or from a scanned image. This effect is called moir? and is caused when a fine pattern in the subject (such as the weave in a fabric or very close, parallel lines in architecture) matches the pattern of the imaging chip. When two patterns meet, often a third, new pattern is created. This third pattern is called moir?. In order to reduce (or eliminate) moir?, a special anti-aliasing filter is mounted in the camera. If too strong a filter is mounted an overall soft image will be produced, but with no moir?. If a weaker filter is chosen the image will be sharper, but there is more of a chance for moir? to happen in some circumstances. Nikon has chosen to produce the sharpest image that can be made, even though there may be some moir? in parts of some images. To help reduce moir? there are many techniques to use: Change angle of camera. Since the angle of the camera and subject causes moir?, slightly changing the angle of the camera (by rotating the camera) can remove or change any moire that is present. Change camera position Again, changing the angle relationship by moving left or right, up or down can reduce moir?. Change focus point Moir? is caused by very sharp focus and high detail on fine patterns; slightly changing the focus point changes the sharpness and can help to remove moir?. Change lens focal length Different lenses or focal length settings can be used to alter or remove moir? Remove with software Nikon Capture (as well as several third-party, Adobe® Photoshop® plug-ins) can be used to remove any moir? that does appear in the final image. Of course it may not be possible to remove all moir? in all cases, but in general an overall clean, sharp image with slight moir? is preferred over a soft focus image. Moir? can happen with images from all digital cameras and scanners, but is more likely to happen with an SLR-type digital camera system because the lens, sensor and software are designed to produce the sharpest, most accurate image possible. When reviewing images to see if moir? is present be sure to be looking at the image on the computer screen (or the camera's LCD) at the full, 100% view. If you zoom out on-screen a false moir? can be produced by the pattern of the monitor grill.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Compaq Presario Notebook Logo
148 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
