Question about Garden
Jet stops and water comes out of main unit
Hi, my Karcher k2.110 will be working fine and then suddenly stop working, with water coming out of the bottom of the main unit itself. I have removed the lance attachment and tried using just the gun but have the same problem. the problem is intermittent and it doesn't seem that there is any specific action that fixes it, it just starts working again with normal pressure. can anyone help? thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Water usually only comes out of there if its hot or damaged. if water is hot its ok, check for temperature anomolies, if water is not hot replace temperature relief valve
Posted on Apr 21, 2014
SOURCE:
hemantraj
  • 638 Answers
SOURCE: Karcher K4
It sounds as if you might have an air lock/air bubble in your pump circuit. If you've not already done so, try holding the trigger on your high pressure nozzle for several minutes with the engine OFF. (just your water pressure forcing water through the unit) Repeat this a couple of times, if necessary. If an air bubble is the problem, this should clear it. The only other thought I have is one of your household water pressure...is it adequate? Low water pressure at your faucet could also be a factor. Consult your manual. It should specify the minimum pressure for your washer to function properly, probably stated in gallons/minute.
if this solution helps you any way rate it as "fixya". feel free for further assistance. thanks for using fixya
Posted on Jun 10, 2008
  • 94 Answers
SOURCE: Karcher 211 - no motor action
Dear Tigger82 (also montaver2000),
This explaination is relavent to various Karcher models, especialy your model. When you are using the machine with the gun open....presurised water comes out of the lance. When you close the gun, the machine stops. This happens by means of a Spill Valve or often called the Control Valve. When the gun is closed, this spill valve cotracts with built up pressure and at the same time works on a miro switch which cuts the electricity....and thus stops the electric motor. Now in many cases when the gun is again opened, this spill valve sticks and keeps the electric circuit closed.
In all cases you must open the cover, and locate this spill valve. Sometimes it is easy to see a micro switch on it. If you remove the miro switch from the spill valve the motor will for sure turn.
Now the spill valve gets stuck for many reasons. One of the reasons is that you leave the machine under pressure for a long time and even store away the machine with pressure still in the system. A spill valve also gets stuck due to detergent. I sometimes service the spill valve and lubricate with special solicon grease. But the best way is to change the spill valve with a new one. So in a few words, the spill valve is stuck and leaving the microswitch off. So the electric motor cannot turn. One final hint is that sometimes the spill valve is difficult to remove. So all one has to do is attach water supply and switch on the pump. With the pressure produced the spill valve will be pushed out. In my oponion this job must be done by a person who knows what he is doing. Carefull that you have safety electrical breakers. See that you have safety shoes, safety gloves and eye protection.
Regards,
Fulltech.
Posted on May 26, 2009
  • 74 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
SOURCE: Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
Posted on Sep 01, 2009
  • 5603 Answers
SOURCE: Hello there.My Karcher pressure washer motor
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Posted on Oct 03, 2009
Hi, My karcher 5.86 has suddenly stopped working. No power/ noise from washer when power is switched on. Fuse & source is obviously fine. Im going to obtain relevant torx screwdriver this week to open...
If its not the fuse in the plug it might be the on/off switch. I would check switch for continuity with a multimeter to rule it out first.
Feb 01, 2015 | Karcher Garden
Karcher troubleshooting
check your lance nozzle is not blocked... Remove the lance from the trigger assy and see if you have water coming through then. If you do then the nozzle is blocked :@)
Jul 21, 2014 | Karcher K2.26 Electric Power Washer
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
I started working with the Karcher KB4040 pressure washer and all was well for 1-2mins, then it sputered a bit and all power died. All hoses were still attached properly, it hadn't blown a fuse in my house...
if the water is in anyway impeded, like kink in hose the unit turns off and goes into protection mode. That it it shuts down for a pewriod of time depending on how hot it may have got.
When its rested try it again ensuring you definitely have water flow.If the solenoid has failed it costs about !60-200 to fix as they replace all seals regardless
Jul 22, 2009 | Karcher 1750 psi Electric Pressure Washer
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
