Question about Compaq Presario Notebook
Replacement power source
We need to find a replacement power source.
Hey there i have a extra power supply i do not need, can sell one let me know jchapman67042@gmail.com
Posted on Jun 01, 2008
  • 328 Answers
You need to tell me what brand and model it is. Here is a link to a few types. Just look for your brand and model and see what the part # is. You can then order it wherever you like.
Posted on Oct 28, 2007
47 LG tv with blown power board - need to identify replacement options
https://www.ebay.com/itm/Vizio-0500-0412-1000-Power-Supply-/292401650643
Feb 12, 2018 | LG Televison & Video
Need a replacement power AMP and a service manual
Fixya does not sell replacement power amps. If you can identify the instrument, try Googling (brand)(model)(manual) without parens for information.
Jul 11, 2016 | Music
Why red light blinking on dell poweredge 840
Check your power supply or the power supply source (outlet or UPS unit) as well as the power cord. Your system power source is not at the correct amp, voltage and may need replacing.
Good Luck.
C2Solutions
Feb 14, 2012 | Dell PowerEdge 840 (becwmk1_2) Server
Why won't it plug into my Toyota Highlandr power source or the lighter?
You need to check if the charger is working properly first before you can tell where the problem is from. Try to use the charger in another cars cigarette lighter or the power source, if it works there, then it means the problem is from your cars power source and cigarette lighter and if it does not work, then it means it is the charger that is faulty and need to be replaced. Hope this information was helpful.
Jan 16, 2011 | GPS
Kyocera mita 5035 code 6400 c
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
I need to know the amperage for the power source for the tiny tailor. The power source is missing and i need to replace it.
I have the original power source - it is Hon-Kwang, class 2 transformer D45-10
Input 120V 60 Hz 12w
Output 4.5Vdc 800mA
Hope that helps - that is all it says
Dec 16, 2010 | Singer Tiny Tailor TT700
Fault code f1 maytag bravo washer
F1 indicated machine controller has failed and will need to be replaced.
May 31, 2008 | Washing Machines
Smart set clock dead ?
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
May 18, 2008 | Emerson Smartset Clock Radio
Astar ltv-1701
It sounds like your power source module is defective. I suggest you try to replace it from one your might find at a second hand store. Look on the back side of the power source device. It should list the output voltage (usually DC or direct current as opposed to AC or alternating current) and also lists the current in amps that it produces. Also inspect the connector to your TV so you can try to match the connector when you buy a replacement. Armed with that information (output voltage and current ability from the power source) pick through the modules you find at a second hand store. Make sure the voltage exactly matches. You can also purchase a power module which can produce more amps of current, but never less. If you are successful in finding a match, buy it - but you may need to cut off the old connector and some of the wire that plugged into your tv so that you can reuse the connector on the used unit you just bought. You will need to splice the old wires from the tv connector to the wires coming out of the used power unit. Assuming the connector on the used unit you purchased did not match your tv connector, you will also need to cut off the connector and splice the tv connector to the wires coming out of the used power unit you just bought. If this is too complicated, go to the manufacturer and try to buy a replacement or look at other places like eBay for a matching power unit to the original TV unit.
There is a possibility your TV itself has a short and is defective, although from you comments I think it is more likely you power source unit.
Jan 23, 2018 | Astar LTV-1701 Television
Alarm
Feb 14, 2008 | Emerson Smartset Clock Radio
Compaq Presario Notebook Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
