Klh audio system
Hi, I have a pair of KLH Virtuoso Mod. 81 and need to replace the tweeters. As I cannot find/buy the original tweeters her in Germany I will use a Germann make. But in order to select the right ones I Need to know the Impdance of the original tweeters for this model.Thanks for any help. brgds Jens ( jml@unitybox.de )
  • Jens Lilleboe
    Jens Lilleboe Feb 27, 2014
    Th tweeters are not blown. The plastic material/covers are broken so the tweeters cannot be mounted.
  • 238 Answers
SOURCE: KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Posted on Jan 12, 2008
robotek
  • 1512 Answers
SOURCE: Tweeters????
Hi oddone
You may have a problem with either blown tweeters, or a faulty cross over, or both. If you have a multimeter, you can remove the tweeter, and check it DC resistance. They normally have their impedance marked on the back of the magnet. If not, you can assume they should measure 8 ohms. If they measure open circuit (high resistance), then they have failed.
A good speaker repair guy can often fix an open circuit tweeter as they often break where the very fine wires attach from the voice coil to the terminal. you can take a turn of the voice coil and reterminate to solve this problem. If the voice coils are burnt, they will need to be replaced.
If the tweeter meters ok, then you may have a problem with the crossover capacitors going dry. Generally they are 2.2uf to 6.8uf in value, the smallest cap in the crossover. If the plastic coating on them is split, or they look a different colour to the rest of the caps, replace them, if they sound "hollow" replace em, if you are not sure, replace em. other than that there is not alot more to look for with a speaker box tweeter Good luck and happy listening.
If you have any dramas, get back to me here and we can talk more about it.
regards
Graeme
Posted on Mar 16, 2008
dunnbiker
  • 8546 Answers
SOURCE: KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Posted on Jan 31, 2010
SOURCE: can't find specs/maker of klh 900b tweeter
KLH 900B tweeter specifications: 6 ohm, 40 watts. By the way, KLH's QC for speakers could be improved. One of my 900B tweeters quit because the spacing for the voice coil was way off reasonable tolerance and the body of the speaker coil base pillar (ie: magnitized part) was off-center - and cauesd the coil to ware and short. I contacted KLH but they did not respond.
Posted on Apr 09, 2010
SOURCE: hi i have a older
You can use 4 speakers. Connect 2 speakers to the A system of the JVC and the other 2 to the B system. Then select in JVC the A+B speakers position. As your receiver is stereo, this is the way you could best distribute the sound. However, if you have only 3 speakers, it would be dangerous to try wiring the third one without changing the whole impedance. So you may use 2 speakers.
Posted on Sep 08, 2010
I DON'T KNOW ALL FEATURES AND CONNECTIONS FOR MY KLH R5100 AUDIO VIDEO RECEIVER.I NEED A MANUAL FOR MY RECEIVER.
I don't have the manual with me. I found KLH R 5100 with user manual in the following link. Tray to contact them.
OK
http://www.ebay.com/itm/KLH-R-5100-Receiver-Hi-Power-/250902259353
Nov 01, 2011 | KLH R5100 Receiver
I have a KLH model 20 stero music system - purchased ~ 1970- that needs amplifier repair. Is there a service location in the Boston, MA area that can diagnose and fix this problem?? I live in Wakefield,...
Check the yellow pages or web search "klh repair boston massachusetts" or "hi-fi repair...."
Or heed this...
http://www.klhaudio.com/faq.html
"Does KLH have service centers?
No. We have opted to internalize all repair services at our facility in Van Nuys California in order to maintain tighter control on our product."
Jul 25, 2011 | KLH Audio Players & Recorders
I need th owners manual for KLH DVD player, #HA9000
Here's what I could find for KLH.
Customer Service
p: 1-818-767-2843 Ext. 117
e: bill@klhaudio.com
KLH Audio Systems
P.O. Box 853
Santa Ynez, CA 93460-0853
I Hope this helpful.
Bobya.
Jun 08, 2011 | Televison & Video
Klh dvc-2500 How can I lower the volume? Setting "1" is too loud. Is there some aftermarket gizmo I can wire into the speaker wires?
Your problem is VERY common. It's defective, get a replacement.
"http://alatest.com/user-reviews/other-home-audio/klh-sequel-e-series-dvz-2500/pu3-38645822,106/?sid=230492&sort=-source-rating&limitstart=10
2.0 out of 5 stars Not bad for price $70+$30 S&H, October 20, 2003 By A Customer
This review is from: KLH DVZ-2500 DVD Home Theater System (Electronics) I read alot of the recent reviews before purchasing this system. I wasn't going to buy it because of the volume problem (too loud) but some people said that this could be lowered in the 'audio properties > dynamics' setting.
Sure enough, there is a setting, but it does NOT lower the volume level at all. So, I rang the toll free 888 number and this audio level problem is a defect. However, the dynamic setting is purely to make some sounds softer, not to lower volume. I was told to get a replacement. The replacement is the exact same way ... defective. Buy this system if you only want to hear _DVDs_ with all speakers, because there are no inputs. And the radio, CD is at best stereo,
AND
if you don't mind the fact that it will be too loud, if at any stage you want a normal listening level. I gave 2 stars because I was able to watch a DVD ok with volume level one.
Feb 26, 2011 | KLH DVZ-2500 System
Can't find specs/maker of klh 900b tweeter
Sep 19, 2009 | KLH 900B Main / Stereo Speaker
Jan 11, 2008 | KLH HT-9930 System
CD-R does not read disks anymore
I recently resolved CD-R recognition problems with the KLH CDR2000. It's absolutely imperative that you utilize CD-Rs bearing the logo "COMPACT DISC DIGITAL AUDIO RECORDABLE". These specific CD-Rs are designed for digital music recording with the KLH CDR2000 and other simular products. I have a Marantz CD20 that has the same CD-R requirement. I purchased a Memorex 50-pack from Best Buy for approximately $20.00 plus tax. The recordings with the Memorex CD-Rs are immpressive for the KLH CDR2000 given the obvious flaws in design. Again, when searching for compatible disc for the KLH CDR2000 look for the words "DIGITAL AUDIO" within the "COMPACT DISC RECORDABLE" logo.
Jan 25, 2007 | KLH CDR2000 2-Disc CD Recorder
43 people viewed this question
 Grubhead
Grubhead
