Question about LG Studioworks 700S 17" CRT Monitor
Red colour disappeared
My Lg monitor 700s CRT has lost its red colour...what to do???
sometims it appears for few seconds and then disappears automatically....
    Problem Solver:
  • 7 Answers
The bad news is this isn't really a solution. You should seriously consider getting rid of the CRT and going with a flat screen LCD monitor. It is 2009 after all...
Posted on Jun 11, 2009
SOURCE:
Hp monitor vga cable wiring solution
Hi,Sir/ i have lcd monitor Hp-L1502 its on position wen i start lcd without vga cable to frount lokation is red+green+blue colours step by step fliker&i can fix new vga cable.whats sulution?
Nov 10, 2011 | LG Studioworks 700S 17" CRT Monitor
My monitor is flickering
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software monitor may flicker and goes into rolling state due to dust, overheating after a long continuous usage,loose circuitry or due to some electromagnetic interference with other like tv , UPS, large speaker systems etc.
FIX :
1.Try Re-installing your Video driver
2 If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
3. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
4. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
If you don't think any above possible reasons for the rolling or flickering state of your monitor then we recommend you to get your monitor checked by the monitor company at their respective service cente
Sep 01, 2011 | LG Studioworks 700S 17" CRT Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
The colour of our sony tinitron color tv model no.kv-xf21m83 has got fading (Red colour disappeared )and the indicator flashes red a number of times between 3 second intervals and the est is sparking
hi
this sounds as if the tube (crt) as a intermittant short in the red gun , try tapping the neck of the tube very softly with a screw driver handle, this just might just clear the fault
regards windyhouse
Apr 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
There are 3-4 patches of colours on the sides of screen what is the problem in the monitor ?????
Sounds like a magnetism prob on your monitor. It happens occasionally and/or if a magnetic force has gotten close to the screen on CRT monitors. Speakers have magnets inside and many people place their speakers right next to their monitors. For your LG Studioworks 700S. I located a manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/700S-_E
Inside, on page A7 it indicates that the monitor has a "Degauss" feature. Activate it and your screen will jump around a bit before straightening out. This helps to restore the image.
Jun 11, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
LG 700E COLOUR CHANGES
you have touch up the solder point at the pict board. Because the solder joints dried up - lead poor contact.
Nov 29, 2007 | LG Studioworks 700S 17" CRT Monitor
Green color missing from my LG 700s model
as you are electronics engineer so let us discuss technically.
as you are unable to see green colour means you might be seeing picture of magenta colour
as technically
red+blue = magenta
crt has got three cathodes
your two cathodes circuit is fine one ckt that is green cathode circuit is not working.
for that problem your will have to check
  • cable from computer to monitor
  • loose contact in crt base.
  • crt connector loose
  • voltage on green video output.
  • green video output transistor might be defective.or print loose.
  • circuit related to green video ckt
  • green video signal coming to green video ckt.
  • & finally crt defective (in rare case.)
  • hope this will help
  • good luck.
Oct 16, 2007 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
174 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
