Question about HP Pavilion zd8000 Notebook
Won't power up
My laptop won't power up.  It tries to power up, then stops and makes a hiccup noise.  It then powers down and tries to power up again.  This happens over and over again.  The only way to stop this is by unplugging it and taking out the battery.  Help!
  • 3 more comments
  • Grags Oct 29, 2007
    No beeps, just the sad hiccup sound.  I don't get a display or anything.  It sounds mechanical.
  • DaveX May 07, 2008
    I have the same problem as Grags and i cant get the notebook started. I dont know what BIOS or CMOS are. Help!
  • briggshome12 Dec 31, 2008
    my laptop hp pavilion dv 6500
    after resetting the bios it came on once and never again
    plz hlp me !!!
  • esteps29 Mar 02, 2009
    my hp pavilion dv6000 has the same problem, it will turnon but after the HP logo screen it will power down and then loop all over again..this problem started after my cat knocked my laptop off of a stool that is only 1 foot from the ground...im thinking it has disconnected some cord or something...also when i go into setup i choose to do a primary disk check and it says "no ide device"...please help!!!
    Thanks,
    Clueless
  • mike_boland Mar 17, 2009
    The first few times I had this problem (constant reboot cycle that could only be stopped by holding down the power button) I could get it to eventualy boot by forcing it to power down, wait about 2 min and boot up. When it is in the constant reboot cycle it does not even get to a point where it is sending a signal to the monitor. If it ever got that far it would boot. After a few days this would no longer work and I got mad and just put it away for about a month. Got it back out and turned it on and it booted. I remembered that the only thing that had changed was that I had put on XP SP3 just befor I started having the problem. The first thing I did was remove SP3. After that was complete I had to reboot. Guess what....friggin reboot cycle again. Over the next week I'd try to boot it up about every other day. Nothing. Constant reboot (only takes about 5 seconds). No signal to the monitor. No chance to enter bios. Will not boot to bootable CD. I'm guessing it's a bad hard drive or bab memory. Any suggestions? Please help. It's a very nice lap top WHEN IT BOOTS!
I have an HP Laptop zd7020us and I had problems with it booting up. When I turned it on, it would run for about 15 minutes and then freeze. CTL-ALT-DEL would not work, so I had to power down by holding the power button for 4 seconds. After troubleshooting for quite some time, I finally found the problem. I had two sticks of ram and after trying each stick individually, I am running with only one stick. The other one was faulty.
Other indications that this might be your problem: After it runs for a short time, it will not allow you to boot up again. All the power lights come on, the fan kicks on, and you can use the CD/DVD drive, however, it doesn't POST.
This is an indication of faulty RAM.
Hope this helps someone and stops you from buying a motherboard unnecessarily.
Posted on Dec 14, 2008
  • 1,006 Answers
Did u hear any beeps???
Posted on Oct 28, 2007
  • arben pllana
    arben pllana Oct 29, 2007
    This error can be caused by one or more of the below possibilities.
    Floppy or CD that is not bootable is cur...
    BIOS or CMOS setup is not setup properly...
    Hard disk drive does not have bootable f...
    The hard disk drive is bad or not connec...
    Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
    BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
    Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
    Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
     - Floppy drive
     - CD drive
     - Hard drive
    Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
    Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
    Windows 95, Windows 98, and Windows ME users
    Boot from a bootable floppy diskette.
    At the A:\> type fdisk
    If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
    If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
    If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
    Once at the A:\> type, sys c: (only do this command if you are using the same operating system that this diskette was created on).
    This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
    If system was transferred successfully, reboot the computer and issue should be resolved.
    Windows 2000 and Windows XP users
    Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
    Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
    All users
    If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
    If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
    Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
    check power suplay and ram???Let me know if u get help???
Monitor won't come on when power on
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Apr 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Hp laptop won't power on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 11, 2012 | HEWLETT-PACKARD G72250US Laptop
Laptop won't turn on
Remove main battery and try again, have the power supply adapter checked, the DC jack in the motherboard is another source of trouble from no power to intermittent operation, at this point the laptop must be dismantled to down to the main board to address the issue.
May 25, 2012 | Lenovo IdeaPad Y530 Laptop
Dv6000 won't power up
Remove main battery and try again, next! have the power supply adapter checked for output voltage, if okay! the DC jack in the laptop is a common source of trouble, at this point the laptop must be dismantled down to the motherboard level to address the situation.
Apr 26, 2012 | Computers & Internet
MY SAMSUNG P35 LAPTOP STOP ITSELF ON BATERY AND AC POWER
This maybe heat problem.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 27, 2012 | Samsung P35 HZM (NP35TP0FL2/SUK) PC...
My laptop was left with the top down and turned on. It was plugged in and when I opened it to use it again, the screen remained black. I tried using different keys but nothing would happen. I unplugged...
Hi, Nan.
Disconnect the power adapter, flip the laptop, unlock and remove the battery. Then, reinsert and lock the battery, connect the power adapter and try again.
Hope this helps.
Jul 30, 2011 | Toshiba Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
Won't power up
I can't help you with the first problem, but as far as the wireless card, if you reinstalled Windows, you have to reinstall the wireless card driver.
Sep 10, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion zd8000 Notebook Logo
357 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
