Question about Kodak EasyShare Z740 Digital Camera
Dropped Kodak Z740 lens won't open/close
Oh..I'm so embarrassed to say this but I dropped my Kodak Z740 camera.  After dropping - lens would not open.  Then it opened but would not retract.  I'm praying someone will tell me this is a simple fix!!
  • stikster Dec 08, 2007
    Same thing happened to me, except dropped it when lens was open, and it just stays open. When turning on and off, the motor tries to wind the lens in/out but it gives up and shuts down. Cant find service manual so I'm trying to pull it apart at the moment
    Genius:
  • 2,985 Answers
This is not a simple fix
Indeed it may not be fixable
With so many new models coming on line all the time parts are usually available
Kodak Support will advise
Posted on Dec 28, 2007
Kodak m1063 lens stuck closed won't open
I suggest you take your camera to a digital/Kodak camera repairer.
Apr 18, 2013 | Kodak EasyShare V1003 Digital Camera
Kodak easyshare c1530 won't take a picture
If you dropped it why even ask ? it is broken.
Oct 11, 2012 | Kodak C1530 Digital Camera
Error E45
It's a lens fault and the camera needs a repair.
OoW. repair of 88,07 Pounds ex shipping
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 26, 2009 | Kodak EasyShare Z740 Digital Camera
Stays on for only a second
please take your cam to the nearest kodak service center..the cam shows this action, due to either of the following things
  1. you have dropped your camera
  2. you might have dropped in water
please do not try to open your cam unless you know how to do it.it consists of small and delegate parts which must be handled very carefully or it might lead to de-calibration which affects the performance after it is restored to working condition!!!!!
Sep 13, 2009 | Kodak EasyShare Z740 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak Z740
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Jan 03, 2009 | Kodak EasyShare Z740 Digital Camera
Dropped camera, SD card came out. Took 2 more pictures, camera turned off. Replaced batteries, camera turns on and then back off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
I dropped my Kodak Z740.....
take it in for repair, if you do it yourself it may still not be aligned properly. a certified camera technician will have the equipment needed to make the alignment.
Jun 25, 2008 | Kodak EasyShare Z740 Digital Camera
The lens won't come out.
It depends on your definition of shot, it sounds to me like the lens assembly is jammed, this often happens when camera's are dropped. You can send it to KODAK if it's under warranty (which it won't be if you say it's been dropped) to fix and they'll likely replace the lens assembly (they might have another name for it) but if it's not under warranty the cost of the labour and the lens will likely be very close or more than the value of the camera.
Good luck,
Matt
Nov 18, 2007 | Kodak EasyShare P850 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
257 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
