Question about Samsung SCX-4100 All-In-One Laser Printer
Paper Jam Error 2
We had a paper jam, but the jam was cleared.  There is no paper left stuck in there anywhere.  We have opened all the doors and drawers and even tried using canned air to see if it was dust buildup or something causing the jam sensor to sense a jam, tried resetting, tried turning it off for 10 minutes, unplugged it, but it still says, "Paper Jam Error 2 Check Inside"
Any solutions?  Until this we were very happy with the printer.
  • callan Oct 29, 2007
    Problem solved!  THANK YOU!  There were a few plastic pieces on springs at the exit of the paper path and one was wonky (crooked) so I straigtened it, there was also a little black plastic bit that fell out when I took it off the desk to look at it closer so regardless of which it was it is now working.  Thanks again.
  • Anonymous May 28, 2008
    I cleared one page by pulling it out of the normal exit port ,recycled the door several times, checke to find no paper caught inside , recyclen paper drawer several times, dis connected power several times and rebooted several times, still it insists on moving betweeenready 100% and paperjam 2 see inside. all tis happened after simply running out of paper and refilling paper tray! I am at my wits end! The device has been delightful up til now!
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to www.samsung.com - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Posted on Mar 18, 2009
Samsuing SCX 4200
would not give up [Paper jam 2 - Check Inside] alarm
no jam, nothing broken, turning off etc. no help
Finally put a sheet in halfway through the manual feed slot
- had door open doing it so I could make sure sheet went far enough so that the little two-pronged black flag right at front of the paper feed opening was kept pushed down by the sheet.
Then used Copy to copy the sheet - this got rid of the false alarm. Prints ok again.
Posted on Feb 22, 2008
    Scholar:
  • 121 Answers
As the paper passes through the printer, it pushes against little black sticks that wobble back and forth to trip the different sensors.  These little 'flags' usually kind of stick up in the middle of the plastic along the paper path.  Look over the whole paper path and find all the little flags and make sure they're all moving freely.  Sometime you can knock them out of place while removing a jam...then you can't get rid of the jam error.
Posted on Oct 28, 2007
  • Eric Engel Oct 29, 2007
    Glad I could help.
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Says paper jam but can't find any paper anywhere
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Paper jam message does not clear after paper jam has been removed
1. Turn off your copier
4. Repeate the above step for all buttons that you can find to access the inside of the copier
6. Turn on your copier
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
5,225 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
