Computers & Internet Logo
A
Anonymous Posted on Feb 27, 2014
Audio Driver vaio vpcea390x
USB mouse sender was hit and pushed USB connector off audio board. Otherwise board looks undamaged. headphone jack not working. Speakers OK. Board shorted by USB jack when pushed in?
robertmoore1
Level 2:
  • Expert 179 Answers
  • Posted on Oct 25, 2014
robertmoore1
Expert
Level 2:
Answers
179
Questions
0
Helped
41242
Points
364
I'd say you need to get an experienced repair person to resolder the connection.
I can't find where my microphone goes
Is your computer a laptop or a desktop? How old is it? Which make/model of computer do you have?
For an older desktop, the microphone input will be on the back of the computer. There are usually three 3.5 mm jacks for audio connections. The pink connector is for the microphone. The black connector is for Line In and the green is line out (speakers). Often they are towards the far side of the motherboard connections from any PS2 (keyboard and mouse) ports. Otherwise, they will line up with one of the card slots.
Newer desktop computers often have additional audio ports for surround sound. However, the pink jack for the microphone is standard. If the computer has front audio ports, you may find that the same color labels the jacks. Otherwise look closely at the icons next to the ports. These will be in addition to the back audio ports.
Laptops can have the audio ports on the front, back or side depending on the model. There will be a small icon with a stand microphone indicated for the microphone port.
If you have one of the newer USB microphones, plug it into an available USB port.
If the computer has no working audio ports, either get a USB microphone or add a sound card.
I hope this helps. If you add a comment with your computer's brand and model number, I'll try to provide the exact audio port details. (There are some computer motherboards that do not have on-board audio and you will need a sound card.)
(on Windows computers, you may have to change the default audio input. Click Start > Control Panel > Hardware and Sound > Sound > Manage Audio Devices. (for Windows 7) For other versions of Windows, you may find slightly different titles in the Control Panel.)
After swapping out a broken fan for a sony vaio SZ-4MN, the internal speakers no longer work;however,sound still plays from the headphone jack. There was no change after all software was restored to...
Seems that you forgot to reconnect the internal speakers to their dedicated connection on the motherboard. In order to fix this, you will need to disassemble the laptop again & reconnect these wires.
1helpful
Where do I plug my headphones into a Sony DAV-FX900KW home theatre system? I'm playing X-Box 360 (on TV/VCR1) but can't get any sound off my Philips wireless headphones. Appreciate any help
There is a headphone jack on the Sony's front panel, on the right near the bottom edge. Connect the sender part of your wireless headphones to that jack. You may need some form of adapter depending on the sender's input connectors. If the wireless headphone system is working properly, this will give you sound.
I have Acer aspire 5741, OS: win7. The problem is that when I plug in headphones or 2.1 speakers the sound get worsed and I hardly could hear anything. I've insalled latest realtek sound drivers but that...
hi Dzhamal23.
you may need to setup the sound for your speakers.
First Check if your headphones work on rear audio panel or not. If they work there then you need to set your Realtek HD Audio to recognise your headphones. Do this:
Open Realtek HD Audio Manager from control panel or from notification area icon(a brown coloured speaker).
On the dialog box just below the close button there is written 'Device Advanced Settings' (no need to change the settings) and below this there is a Folder icon which shows tooltip text Connector Settings when you hover your mouse over it.
Click open the Dialog Connector Settings.
Tick the checkbox against Disable front panel jack detection and click OK.
i also found this on the internet.
So I have contacted Acer and I isolated the issue they dont support the issue but I have found through research that the motherboard has a problem relating to the headphone jack I have seen then listed for sale on Ebay with broken audio jacks I used a usb headphone set and received clear sound and after removing the third party software the speakers are sounding good too... if you have a nice set of mm headphones then you can buy an adapter that converts usb to mm so you can use them this way and that will prevent having to replace the faulty motherboard/audio jack
or go to this link and it will give you step by step on what to try out.
Fix Windows 7 Headphone Not Working Issue Driver Easy
2helpful
Where does the Microphone plug in to the Dell Vostro200
Depending on the chassis-style of your Vostro 200 (Slim-line or Tower), you may have one or more options for installing a microphone.
See below for instructions:
A. Slim-Line Model
There are two locations on this model (by default).
Front: You have the power button, then 2 x USB ports, 1 x Headphone jack-out, and 1 x Microphone jack-in.
Rear: There is a block of six audio connectors, looking only at the bottom 3 (red, green & blue).
Red = Microphone jack-in Green = Speaker/Audio jack-out Blue = Audio jack-in
B. Tower Model
There is one location on this model (by default):
My audio out put is damaged, any way to re-route
Audio jack on any mother board runs on Mic and Headphone outlets.
The design of the board and the chipset wouldnt allow the headphone to be used in the microphone jack. Instead you have the option of using usb headset which has a driver pack to be installed and it goes fine. I am not sure if you have the product available at all stores. Good Luck
Headphone jack seemingly screwed up
What generally happens to connectors, especially exposed to air is they oxydize.
Buy a can of "Contact Cleaner" from a local Radio Shack and spray it (through the thin tube usually provided) into the jack. One quick push, dont flood it. Take the earphone jack and insert and remove it several times, wiping off excess, which sould clear contacts and it should work normally again. If not it would have to be replaced which is no easy matter requiring an experienced Technician or Factory. Sometimes it cannot be replaced without damaging the Mother Board. This however sounds like a common problem the Contact Cleaner will fox
Cheers,
Good Luck :)
Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
2helpful
Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
1helpful
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Grand Canyon Tech
Grand Canyon Tech
