Question about ViewSonic VP181 18.1" LCD Monitor
Where to find replacement key controller board for vp181 base
One of the keys on the base of my vp181 viewsonic monitor has stopped working.  it doesn't seem to be springing back when pressed.  it could be worn out from overuse or it may have been damaged by a soft drink mishap.  i've taken the base apart and observed that the actual key device isn't springing back.  it and the other six keys are mounted on a detachable board, so it seems I should be able to get a replacement, but I don't know from where?  any thoughts would be appreciated.
2 Suggested Answers
SOURCE: Viewsonic VP181 power adapter barrel jack size
yes. it is a 5mm center hole
Posted on Dec 18, 2007
I have a Viewsonic VP181 monitor that has a intermittent problem. When I start the computer, the power light on the power button is yellow and there is no display. If I unplug the monitor from the...
You might need to replace the board that has the d-sub connector on it, ebay might have that, this is a fairly used monitor if you where to have it replaced by a repair shop it might not be worth your wild on it but its up to you. i price this board around
$35-50 bucks respectively.
Sep 27, 2010 | ViewSonic VP181 18.1" LCD Monitor
Trying to pack
Few steps to take the stand and base off the 22" ViewSonic VX2235WM
1- Squeeze the bottom of the base to take the base off from the collar
2-This step is very important. The collar has two parts snapped in together, with 3 snap in each side. Carefully use small flat screw driver to take off the back side of collar
Feb 19, 2010 | ViewSonic VX2235WM Monitor
Won't power on
check your power supply maybe its too old to work for your computer. If the power supply is not the problem try checking the cables, there might be loose connections.
Also , you should check the power source of your home, maybe you have a low voltage and that wont turn on your monitor.
Jan 03, 2010 | ViewSonic VP181 18.1" LCD Monitor
I have viewsonic 1703wb monitor. Often Monitor power went off
Check the power cable. If it uses a power brick style assembly (like a laptop) it may need to be replaced. Some power bricks can break a wire at the base of the brick just enough that it causes a short in the system and shuts down the power flow.
Mar 19, 2009 | ViewSonic VA1703wb Monitor
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
Starts up looking good then in 3 minutes, all hell...
Go to the ViewSonic site and read through their knowledge base on your monitor.
Then once you familiarize yourself with electronics safety by reading through a basics manual once or five times, and once you've got it, open up the monitor cold and/or hot, and find out where they spilled Coca-cola down the back or whatever might be suggested by the ViewSonic knowledge base.  Lather, rinse, repeat; when the monitor acts right, then stop.
Dec 09, 2007 | ViewSonic VA520 15" Flat Panel LCD Monitor
ViewSonic VP181 18.1" LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
