Question about Garmin StreetPilot C330 GPS Receiver
Garmin C330 white screen
When I turn the unit on all I get is a blank white screen. I tried the reset button but it still shows a blank white screen.
  • Anonymous Nov 16, 2007
    Mine is doing the same thing. When I turn it on, I get only a white screen. I just updated the firmware to 5.70 and it's still doing the same thing. Any ideas?
  • Anonymous Mar 23, 2014
    when I turn the unit on just shows dark blank screen.
  • 504 Answers
Have you tried a Master Reset? If not, it may help, but it WILL ERASE ALL OF YOUR FAVORITES, and may remove anything you have updated. To do a Master Reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but keep pressing the screen until the unit asks if you are sure you want to reset. Press yes. This may help.
Posted on Feb 10, 2008
Brand new unit.Garmin c330, Will not stay on.
Since I didn't hear from anyone, I contacted the co. I purchased from. I was advised to send it back.
May 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My Street Pilot C330 will not navigate pass the where to/view map screen Screen seems to be frozen
I have a c340 and instructions say: if your unit locks up. press the power button to turn off the unit, then press again to turn unit back on. If this does not help, reset by the following: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plate, press the reset button, turn the unit back on and it should operate normally
Dec 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Blank Screen on Garmin C330
It took a nap...
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
IS the battery charged fully? Try turning it on while its plugged in.
Oct 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
put your thumbnail under the silver faceplate above where it says garmin and on the right you will see a reset button. It will reset your garmin and you will not lose your information. Hope this helps.
Patti
Dec 12, 2007 | Garmin StreetPilot C330 GPS Receiver
My garmin 330 doesn't show maps
Did this problem occured after trying to install an update?
Try doing a hard reset on the Garmin
First remove the faceplate from the Garmin C330. To accomplish this there is a small indentation under the word Garmin where you can get a finger nail in and pop the faceplate off. On the right side of the unit is a reset button.
Nov 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
395 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
