Question about Dell Dimension 8400 PC Desktop
Random shutdown When running the PC for a while (sometimes days, sometimes hours or minutes) the PC will shut down. When it does this, I can't turn it back on right away. I have to let it sit for 20-30 minutes. It sounded like a heat problem so I cleaned the inside of the case (looks new) and I removed the CPU heatsink - cleaned the old paste (with cleaner) used new paste and remounted the heat sink. This seemed to help and it ran for days with no problems. However, it's right back to where it was before. I'm thinking power supply. Any thoughts?
  • Javashack Nov 05, 2007
    It's been 4 days and no problems - the power supply looks like the fix.
TRY I think is your power supply.
GOOOd luck!
Posted on Oct 28, 2007
  • 328 Answers
The power supply would have been my 2nd option too. It can build up quite a bit of dust which gets very hot inside and overheats. Good thing power supplies are cheap. I assume since you cleaned the heatsink area that your fan is working and plugged in. A bigger fan might be needed too.
Computer does not shutdown
You have programs running that aren't shutting down, you can choose the force shutdown option to solve your problem.
Jul 27, 2014 | Computers & Internet
Laptop gets shutdown every 15min.
Random shutdowns without a blue screen are usually due to a faulty memory module inside the PC. Download and burn memtest from memtest.org to a CD. The boot from CD and proceed to do a memory test.
Feb 13, 2012 | Acer Computers & Internet
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
Apr 19, 2010 | ASUS Eee PC 1000HE Netbook
Runs good but for random shutdown without any warning,,,
powerdrain pc first. remove battery and ac adapter then press down power button for 15-20 sec. turn it on and check if it will still shut down. observe if it is hot to touch before it shuts down, might also be an overheat issue. if so, need to replace fan and heatsink.
Apr 08, 2010 | Gateway 4540GZ Notebook
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
I have an asus F3Sv laptop\ 8600m gs card\3gb ram\vista ultimate os\this machine has been fine for a year i play games on it (i know there not made for that)the last month or so it has taken to shutting...
It could be a power problem when playing games.
When a games starts up the graphics card starts to draw more power from the system.
Its could be that your graphics card might need replacing or that your power supply might need upgrading. PC systems, more so gaming systems, like to have alot of power.
Also before this I would try and download the latest graphics card drivers, to see if that helps the problem.
Oct 26, 2008 | ASUS Computers & Internet
Shutdown
plz check the power supply
Jul 01, 2008 | E-Machines T6420 PC Desktop
At witts end
Give the vents round the side and underneath a hoover out first, then check in acer e manager, there you should see settings for your fan, HDD and hibernation , you can set the fan on all the time or default, check it's set correctly and see if you resolve the issue. Turn hibernation off and HDD idle shutdown off to see if any change in shutdown. Does the pc shut down in any particular programme?
Jan 15, 2007 | Acer Aspire Notebook PC
Dell Dimension 8400 PC Desktop Logo
91 people viewed this question
Alun Cox
