Question about Acer AL1711 17" LCD Monitor
Shadowing on ACER AL1711 17" LCD Monitor
I have recently gained a monitor and discovered that are bright areas(bright shadows) on the right of objects,icon, letters etc.The length of this area is approx. 1-2 pixels. This hurts your eyes after a while. I note that someone else had a similar problem and was recommended to remove the back and adjust the HV potentiometer.
Does this work?
And how do you remove the back?  I have removed all the screws and cannot open it up?
  • Anonymous Apr 01, 2008
    Same problem here also... i get shadows for everythng on screen ill be glad if any 1 get a solution.. or can any 1 say he how to tune dat hv thng... :D
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
SIMPLE !! The "shadowing" you talk about is due to cables in back of your computer, touching or too close together. I had this happen to mine. I moved the cables apart, and no more shadows !! Sounds too easy, but it works. Takes a few seconds. Immediate results.
Posted on Nov 06, 2014
  • Acer Master
  • 5,568 Answers
Did you ever find the problem with this unit? BTW, a crappy video cable can cause this or the input impedance has changed on the monitor due to improper connections.
Posted on Sep 18, 2008
All the icons, pictures and letters are creating shadows on the monitor. How do I get rid of them?
try this right click on your desktop , click on Appearance tab . then click on effects , see if Show shadows under menus is checked if so uncheck it . click ok then click Apply .
Sep 20, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
All typeset and pictures have shadows/blur have changed out video card on Lenovo computer - seemed successful for a while but now back to square one. any ideas
Try a different "data" cable between the monitor and the computer.
Connect the monitor to a different desktop/laptop.
If the "shadowing" is still visible, then it's the monitor that has gone "bad'.
Connect a different monitor to your Lenovo computer.
If the "shadowing" is still visible, then your monitor is OK, and your video-card is the problem.
May 18, 2010 | Lenovo ThinkVision L192 19" LCD Monitor
Monitor has shadows at edges and beside every object and icon
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Jan 16, 2010 | Hannspree HANNS?G HU196D Monitor
'Shadows' behind all texts and images on the screen
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Samsung 931B monitor - shadowing
I have the same monitor, and twice I've experienced this exact problem. In my case, the video connectors have relaxed. If I wiggle the cable, I can make it better or worse, so it's time to disconnect, reseat. I don't know if it will work for you, but it's free!
Feb 20, 2009 | Samsung 931BF 17" LCD Monitor
Desktop icons appear as a shadow on all windows.
Thank you.
Sep 29, 2008 | Acer AL1714 17" LCD Monitor
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Desktop icon shadow in acer monitor as 1024*768 resolution
go into your graphics card config and change the brightness levels
Feb 03, 2008 | Gateway FPD2275W LCD Monitor
Ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1711 17" LCD Monitor Logo
272 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
