Problem with Salton RA5 5-Cup Rice Cooker
Salton GM-5 yogurt maker
I have an old but working Salton yogurt maker - no recipe booklet. Is there a simple recipe you can give me that will work with this?
Posted by avatar on Oct 28, 2007
    • By avatarcjm93010 Mar 05, 2009
    • Does anyone know where I can get a copy of the booklet for the Salton GM-5 yogurt maker??
Solutions (1)
Best Solution
Basic Yogurt Recipe 4 cups (1 quart) milk - whole, 2 %, 1% or skim
1/4 - 1/2 cup instant non-fat dry milk powder
1/2 cup plain yogurt (with live cultures) or yogurt from a previous batch
  1. In a saucepan, combine milk and dry milk and heat over medium heat, stirring frequently to just below the boiling point. Remove the milk from heat and allow to cool until lukewarm (about 100 degrees). To cool the milk quickly, place the saucepan into the refrigerator or a sink of cold water, stirring occasionally to cool evenly. This takes about 20 minutes.
  2. Pre-warm the yogurt maker's heating base by plugging the cord into an electrical outlet. The signal light will glow when base is plugged in.
  3. Add plain yogurt to the warm milk, stirring gently to blend. Do not beat or whip. Pour the mixture into the yogurt container, secure the lid and place the covered container into the heating base. Cover the Yogurt Maker and process undisturbed and out of drafts for 4-10 hours, depending on tartness desired. Yogurt should be partially set after processing and will thicken further after refrigeration.
After processing, unplug the cord from the outlet. Remove the cover and lift the covered yogurt container out of the heating base. Place the container in the refrigerator and chill at least two hours to thicken. If desired, remove 1/2 cup of the yogurt to use as a starter for future batches, before adding any fruit or flavoring. Keep yogurt refrigerated until use.
  • By Author imageGuest Nov 04, 2007
Add Your Solution
See all Salton RA5 5-Cup Rice Cooker Problems
