SOURCE: I can not lock the front forks for anti-theft
turn the bars all the way left, and wiggle it slightly as you turn the key, It may also need a little spray grease on the lock pin
Make sure the vehicle is balanced on the centerstand. The centerstand is a metal bracket located in the middle on the bottom of the scooter. Engaging it means that the scooter is resting on the front tire and centerstand. The rear tire is raised slightly off the ground.
Insert your ignition key into the main ignition switch. The switch is located on the inside front of the scooter just to the right of center and below the handlebars.
Twist the key to the left, or counterclockwise, to the position on the switch marked Open. If the scooter is not in the locked position, turn the key to the first Open position. If the scooter is in the locked position, turn the key to the second Open position. In either case, turn the key counterclockwise one notch to the respective Open position. The Yamaha Vino Scooter Owner's Manual cautions you that you should not push down on the key while turning to the Open position.
Grasp the end of the seat nearest the front wheel and pull it upward to raise it on the hinges located at the rear. Now you can store or retrieve items from the storage compartment
