Question about Rockford Fosgate P3001 Car Audio Amplifier
My amp was smoking and I want to know how to repair it.
I was moving the amp around in my trunk and it looks like the postive and ground touched. I want to know how i got about fixing it ? ir if its useless now ?
  • BrendonK Oct 29, 2007
    you mean the car battery right ? or is there a battery in the amp ?
Take a wire and touch the + and the remote wire together
Posted on Feb 10, 2008
  • 709 Answers
The Amplifiers Positive to ground will only hurt the wire to the battery, and blow the main fuse near the battery.  Check the main fuse near the battery.
Posted on Oct 28, 2007
How do I find fuse /relay digital speedometer/info&trip meter buttons 04 cad deville
Look in your owners manual. But remember, blown fuses cut power. WIth a few exceptions related to lighting mostly, things that are acting strange or doing crazy stuff dont have blown fuses. They go DEAD when they have blown fuses. If they are acting strange, something is causing them to believe they need to, or a major compnent of they system is no longer correct (like say a ground connection, or a signal wire rubbing ground partially).
WHen chasing sudden crazies...1st place to look are the last 2 places you touched or moved or even reached past anything electrical. 98% of the time that is where it came from. If that fails, then you need to state exactly what is going wrong and when...what was done/what did you touch when you were trying to fix...and start troubleshooting circuits one at a time. Start with where youve been, see if that works. If not, then make a new reply.
Dec 21, 2014 | 2004 Cadillac Deville
2005 Ford Five Hundred 3.0L Hesitational take off cleaned throttle plate and codes p2111 and p2104 still set. Looked in Mitchells and they're telling me to replace PCM. Any other solutions?
You have one bad COP Igniton Coil
The coil is not grounding out in the PCM
A signal is coming back to the TPS Sensor
& you loose it's signal
The PCM then doesn't know throttle position %
and sets a 2104 & 2111 & you think that you have
a bad Throttle Body Motor (TACM)
A dealer will charge you $1000.00 & fix nothing
Buy one coil for $35 to $50.00 & install yourself
You may have to walk the new coil around a few times
& drive the car 30 miles each time, until you get the bad coil
Repair shops are not good with Fords & Dealers are useless
You should have other Misfire Codes & lots of them
Give them to me
Jul 21, 2011 | 2006 Ford Five Hundred
Where's the positive terminal on the 1997 audi a8. My battery is no longer working and I need to charge battery to get open trunk
If you look at the engine area you will see the postive jump point, let me see if i can locate a picture of this location.heres a diagram of the engine compartment, theres a fuse /relay box in the left rear, this is if you are standing in the front of the car looking in engine compartment, look for a terminal to connect the postive cable and ground the other to metal in the engine compartment, this is only to be used to acess the truck to get to battery, also look around the engine most times theres a postive hook up sometimes neear or on motor,good day,johnjohn2_115.gif
Apr 10, 2011 | Audi Quattro Cars & Trucks
I had a small fire caused by what I think is a loose ground wire that was not attached to my amp anymore. It burnt the driver side of the back seat and i assume any wiring in that area. The car will not...
amps draw a lot of current so it should have been fused to avoid this problem, but since it happened, chances are the fire damaged the harness and burned through wires. When you take it apart you will see the area of damage. and you will have to repair or replace the damaged sections. the wire that caused the fire was probably the positive feed to the amp, somewhere it grounded out and since it was not properly fused it got very hot and damaged a harness that was close by or touching the feed wire.
Mar 22, 2011 | 1993 Chevrolet Beretta
I have a 2002 2.5l nissan altima i unpluged the battery on the negative side and the alternator i changed out the idel arm i put everything back in place now my car has no power at all nothing turns on the...
Have you checked if you have taken the engine ground off towards the othe end while working.(not the battery end)
check for power at the ignition switch
check fuse in the engine bay
check fuse inside the car under the dash
Mar 04, 2011 | Nissan Altima Cars & Trucks
I need to no if the postive battire cable on a mecrury tracer is all black or black with a yellow strip?
It is usually red, but don't go by the color, look at the battery, it has marks on it, and the positive cables will go to a box with fuses, links, never touches ground metal, the negative always goes to something metal, ground. The positive could have a yellow stripe, if the other one is all black, it cold be the hot one. If the battery is new and you don't know which way it goes because of the wires, you can test the cables with an ohm meter, don't touch the battery, don't even put it in the car, put the meter on ohm, put one end on the cable and touch the other end to bare metal, if it goes to 0, that is ground, if it doesn't move, it is pos. You can test the pos the same way, put one end on the cable and the other in the fuse box, somewhere you can find a hot wire in a dead car, don't touch the ohm meter to any voltage or you can throw it in the garbage can. Kind of hard to explain. If I was there, I could spot in a second. Hope this helps.
Jun 04, 2010 | 1993 Mercury Tracer
I cant figure out how to jump start my 1993 BMW 325is
Either hook the jumper cables to the battery in the trunk or hook the postive to the postive stud under the hood( passenger side near the firewall) and the ground to the block.
Mar 25, 2009 | 1993 BMW 3 Series
Jenson a300hlx 300 watt amp
DISCONNECT THE GROUND WIRE. SAND ALL THE PAINT FROM THAT AREA AND REGROUND IT. WHAT I WOULD RECOMMEND IS DRILLING A HOLE THROUGH THAT TRUNK, SAND THE PAINT AWAY FROM WHERE THE GROUND WIRE WILL GO AND BOLT THE GROUND WIRE TO THE TRUNK BOTTOM. THE PAINT WILL CAUSE THE AMP NOT TO GET A SOLID GROUND
Feb 21, 2009 | Jensen A300HLX Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
165 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
