Question about JVC KD-SX650 CD Player
I recently purchased a JVC KD-SX650 from a swap meet and for some reason it will not power up even connected correctly as required. When removing the face plate I noticed that the face pushes in on a black tab that pushes into the stereo on the right hand side if your looking at the front. Is this tab suppose to push against anything internally that gives it the ability to power up? Please help. and if not what are some of the most common reasons for not having power to the stereo when hooked up correctly?
Your battery and accessory wire need to be twisted together. if u already have it like that then im not really sure other than that
Posted on Jul 12, 2008
Hola nesesito la ficha q se conecta atras del estereo es para adaptarle un mp3. grasias
Posted on Jan 12, 2008
Swapped red and yellow wires on my JVC KD-R200, then swapped them back. Now it only powers on when I push the Eject button. Otherwise, nothing
Swapping the red and yellow wires cannot possibly have any affect on the radio. Both wires need to see 12 volts for proper operation. If they are reversed, it would only simply fail to save the memory settings. You have other issues. You have probably lost power on the red wire.
Dec 25, 2013 | JVC KD-R200 Car CD/ MP3 Player
I installed my JVC KD-SX650 and it works but when i turn my truck off it loses the radio station and clock settings, what could be the problem?
There should be a yellow "accessories" wire that controls the memory to the radio. If it is not properly hooked up, the radio will reset every time you turn off the ignition.
NOTE: It might be a different color than yellow, but this is the most common
Jul 13, 2010 | Car Audio & Video
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Jul 13, 2010 | JVC KD-SX650 CD Player
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Need to reset the clock on my JVC KD-SX650
Does this unit have RDS on it? if so switch it on and it should set your clock for you
Feb 03, 2010 | JVC KD-SX650 CD Player
Wont release the cd
Look for the reset button when you take the face off. Press it down with a pen or if cannot find it remove the fuse to the radio and then reinstall it
Oct 09, 2009 | JVC KD-SX650 CD Player
KD sx980
try here
Jun 23, 2008 | JVC KD-SX650 CD Player
Problem with JVC KD-SX650
send me an e-mail I can probably help
KD-G421 in Vectra Envoy 99
To stop the memory loss you need to swap the red and yellow wires around. (battery power and ignition power).
To stop the date loss, you need to cut the electrical ariel/remote blue wire.
Dec 27, 2007 | JVC KD-G421 CD Player
get a good service manual for your car that shows the wiring for the stereo plug. match up the wires to your JVC's wires (solder tie wire-to-wire behind the car's connector)
May 26, 2007 | JVC KD-SX650 CD Player
JVC KD-SX650 CD Player Logo
243 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
