Control panel on hob beeps and flashes every morning and whenever either oven is in use
SOURCE: Morning I have a Stoves EFA600H
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
